Thread: 83 250r carb problem
    Jan 2011
    Laurel DE
    20
    Everytime I go to ride my trike I turn the gas on and when I do there's gas draining right out of the drain hole wayy more than I suppose should be its more like running right out than driping any help please???
    May 2008
    SO CAL
    312
    sounds like the float is sticking, take it apart clean with carb cleaner put it back together and see if that does the trick
    osoyoos bc canada
    1,057
    some times you can tap the carb with something hard but what fmnrd said was smarter and solves the problem perminantly
    Jan 2011
    Laurel DE
    20
    Ok ill try that!! But do any of you guys know why it won't sit and idle?? Or go full throttle when I hit the throttle its like it sounds like the choke is on but I know its off and one more question its smokes alott more for some reasson I'm running 30:1. What's the best to run for less smoke??? Thanks for the help!!
    osoyoos bc canada
    1,057
    if the floats are stuck the motor is flooding causes same problems as haveing choke on
    Jan 2011
    Laurel DE
    20
    Ok thanks man
