Results 1 to 12 of 12
Thread: paint stripper
    May 2009
    monroe, Louisiana, United States
    948
    paint stripper
    i was wondering can you use paint stripper on plastic? because on the tecate i got the gas tank was painted, and the paint is rough. i would rather it be faded plastic then the crap that is on it. or will the paint stripper eat the plastic tank up?
    Michigan UP
    1,005
    I heard that oven cleaner works for taking paint off of plastic, otherwise you could always sand it off, use a finer wet sanding paper and go to it.
    May 2009
    948
    i figured i would end up doing that. i was wondering because i have a dang near full can of paint stripper, i figure i would try the work smarter not harder tactic but shot down lol.
    Nightmare's Avatar
    Nightmare is offline At The Back Of The Pack Arm chair racerFirst time rider
    lehigh valley, PA
    196
    Try a small amount on a small spot first. I think it would be ok personally.
    Ride: 1986 Honda ATC 200x
    Following Mods Done:
    -Anodized blue block-off plate
    -Factory head light and master cylinder guard
    -ITP mudlite SP rear tire/Chengshin turf tamer front
    -DG reverse megaphone exhaust
    -UNI airfilter
    -Moose bars/Protaper Grips/MotionPRO twist Throttle
    -CEET classic ATC blue seat cover (should of sent it to mosh :-(...)
    -Tuned Carb with a 125 main jet
    -COMPLETELY restored gas tank
    -RED/WHITE PowerMadd Handguards
    -1/4" thick aluminum swing arm skid plate!
    Tbcoplin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Hammond, la
    157
    I wouldn't use stripper on plastic. I agree with brain on sanding it.
    84 Big Red- User
    85 250SX- clean
    85 200X- mint- < 10 hrs on it
    85 350X- Mint- <40 hours on it
    86 350X- mint- <40 hours on it
    2-85 tri-z's- Both frame off restorations
    84 250R- Mint- <15 hours on it
    86 250R- Super clean- < 30 hours on it
    86 500R- Sick fast!!!
    86 Tecate 3- Frame off restoration- Mint
    86 Big Red- Mint- <30 hours on it
    ktmbk's Avatar
    ktmbk is offline At The Back Of The Pack Arm chair racerFirst time rider
    Long Island
    154
    I usually like my strippers on stage, might slip off the plastics.........
    oh, sorry then... never mind...
    May 2009
    948
    i think i would have lots of explaining to do to the wife if i had a stripper on my plastices but it would be a neat site lol
    Oct 2007
    Minneapolis mn
    4,067
    I have seen plastic safe paint stripper at my Oreily Auto parts before... Never used it personally...
    May 2009
    948
    thanks for the help fellas
    Tucson
    1,652
    I use stripper on fenders many times, I buy it in a spray can at the hardware store! Don't let it sit on there a long time do as many times as it takes 5 minutes each time, then when done polish it out with plastic polish.
    Nov 2006
    southern oregon
    2,338
    I've used the spray can stuff too.. Duplicolor if I recall correctly.. I just let it sit til the paint softened and then pressure washed it off.. may take a couple attempts..
    2-stroke lover
    861
    Quote Originally Posted by Thorpe View Post
    Thanks for the pointer. I got a 85 R that the past owner painted the number plates black and was sloppy.
    ]1986 ATC 330R
