Thread: Dumb question for the fabricators out there
    zeeker1's Avatar
    zeeker1 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Canton Ohio
    184
    Mulling over the thought of making a set of triple trees for my '70. I have the aluminum and "maybe" enough equipment to get them whittled out but I'm at a loss as to where you get a steering stem bolt the right size. Or do you have to manufacture that also?
    Any help would be appreciated.
    hey, use the original 70 stem.
    one cylinder is not enough!!
    May 2008
    SO CAL
    312
    ask kasey what he has used , he has a few of those 70's with forks on them
    Baltimore, MD
    6,088
    blue27 was making atc70 suspension triples. I believe he was making custom stems for them as well. He has run drum brakes and disc brakes on his front ends. The stock 70 stem will probably not work as the lower triple on the stock atc70 fork is kind of thin and you may not have enough threads left once you mount the stock 70 stem in a "thicker" lower custom triple tree. You would probably have to have a custom stem made as well. You could always contact blue27 and see what he has done or what he could hook you up with. He's a great guy and has helped me on my trikes more times than I can count.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    zeeker1's Avatar
    Canton Ohio
    184
    Thanks for the input guys............zeeker
