Results 1 to 15 of 19
Thread: Axle straightening?
    Leonardtown, MD
    594
    Axle straightening?
    I’m looking at a 85 250r this weekend and the guy says that there is a slight bend in the left side of the axle. He said that on grass/dirt you cant notice it but if you ride on pavement you will notice it.
    He says it’s a durablue 2+2 axle. Is there any way to fix this axle? Is it even worth fixing? I guessing the axle will be weaker if it can be bent back into place.
    It might be the wheel/rim that is creating the wobble but he has two different sets of tires so i'm sure he knows its the axle and not the rims.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    N.E. Ohio
    2,002
    The one thing you need to do is bring a milkcrate/stool, or bikestand to set the rear on any time your looking at purchasing an ATV or ATC. Roll the rearend swing it side to side and look for play in the rear. Axles can be bent back...the heat treatment gives the steel a kind of memory of alignment. Would I trust it? as a spare on the trail? sure. I'm betting it's the hub or rim...much more easy to bend in a normal roll over.
    You can have the axle bent back and it will be no weaker. Dirtcrasher can do it for you if you are looking for somebody to do it.
    Apr 2008
    NW, IND.
    842
    If it isn't bent too bad it can be bent back to shape with a little heat.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Leonardtown, MD
    594
    If i get the 85 250r i think i will send dirtcrasher a PM.
    Thanks everyone.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    osoyoos bc canada
    1,057
    dirtcrasher is the only one id trust that job too most people would screw that up
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    All that needed, is a couple pressure treated v blocks...2 ton press and a round out gauge..easy fix...lol
    glendive, montana
    1,822
    just another reason why I need a house with a big shop and my own lathes, so I can start making new aftermarket axles out of some nice stressproof steel. I see alot of guys on here with bent axels, and making a new one is only about a 4 hr job
    osoyoos bc canada
    1,057
    if you make your own make it from a dodge torchion bar if you bend that it bends back since its spring steel
    Heat will weaken it allot worse than a 20 ton press. Send it my way, I'll get it as close as possible........
    Leonardtown, MD
    594
    Thanks dirtcrasher! If i get the 85r i will send a PM your way!
    If no one else throws him an offer by friday, its all mine!
    Hopefully, its the rim and not the axle... but we will see
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Mar 2005
    overton, PA
    5,257
    i have abent durablue axle also but its bent 3 diffrent places 2 diffrent diretions hahaha can you fix that too dc??
    scottyms's Avatar
    scottyms is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2006
    most any engine shop that does there own crank work can fix them... my local guy gets 40 bucks
    current line up:
    86 KXT250 Tecate
    87 KXT250 Tecate
    86 ATC350X
    87 ATC200X
    85 YTM200
    and about a dozen more in parts...
    Jan 2011
    dallas,nc
    87
    yea its a real easy fix.... like one said... a dial indicator an some v blocks or if ya fancy some bearing blocks... an a press.
    i wouldnt put heat on it either...
    just my opinion.
    good luck!
    Nov 2010
    Rockford Minnesota
    21
    My big red axle is bent on one end. With the shaft drive is it a 2 piece axel? is it easy to take off and straighten?
