Results 1 to 15 of 15
Thread: how do you break a chain!?!?!?!?!?
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    I was told to cut the tip of the pin off with a grinder, and tap it out with a and center punch, I tried this but it didn't work. am i not hitting it hard enough, or what? or does that not work? i don't know, i've never done it before, and i'm trying to get my bike up and running today, I haven't even driven it yet
    Apr 2003
    Spanaway, WA
    1,247
    try getting a chain breaker.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Rittman, Ohio
    6,276
    Grind the portion of the pins off that that stick out of the side plate. Grind them all the way down into the side plate. Then use a and screwdriver, or chissel, and pound it between the sideplate and the roller. It will pop right off.
    leprogle's Avatar
    Mar 2003
    New Brunswick
    345
    is there anyone else that is cheap like me and has broken a chain without a chain breaker?
    Aug 2002
    Creswell, OR
    889
    Yes we are useing methods Tim has described...So yes I guess im cheap,,,,just hit it harder. It can be a bugger..
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
    leprogle's Avatar
    Mar 2003
    New Brunswick
    345
    when i made the post about being "cheap", I didn't know that TimSr had made that post, I just read it now, i must've posted it right after he did.
    but anywho, thanks for the tip Tim
    Rittman, Ohio
    6,276
    Quote Originally Posted by leprogle
    "Necessity is the mother of invention."
    Ive never used a chain breaker, but from looking at one, and understanding how it works, the grinder method would appear to be more effective, so even if somebody GAVE me a chain breaker, Id probably continue with my present method.
    leprogle's Avatar
    Mar 2003
    New Brunswick
    345
    Trikekids post, made me assume everybody on here used chain breakers, but I guess i was wrong. you know what they say "when you assume you make an @$$ out of...."
    I didn't mean that everybody that doesn't have one is cheap, so if I offended you, go cry me a river
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Yeah If my chain is worn bad enough to justify a link removal, I usually just take the chain off, walk over to the bench grinder, and grind the pin till its totally flush with the actual link itself. Then I walk over to the vice, grab a and punch, and usually 2 licks and its out. Chain breakers are probably good for at the race/trail fix, but if you have a shop/garage and a grinder, just use it.
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    Quote Originally Posted by TimSr
    I've done it plenty of times Tims way,and worked great! I say if it doesnt work the first time,do it again!
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    i just use a plug in hand grinder, same methods as these guys, i do have a chain breaker, but it is a bitc* to use, gotta crank on that sucker with like 500 pounds of force, but with the grinder, its a few sparks off the side plate, couple good smacks with , and its apart
    200xer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    I only use a chain breaker on my racing kart chain which is 35 and we don't run master links. I've always used the grinder and a punch with ATV chain.
    85 200x - Torn apart
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    dude did u grind both sides of the link u want to pound out...i would make it a heck of alot easier
    Rittman, Ohio
    6,276
    Quote Originally Posted by timex69
    Both sides????
    Howdy's Avatar
    Celina, Ohio
    10,079
    I have a chain breaker and use it once and a while. I also use the grind and punch method also. I pretty much only use the Chain Breaker when I want to re-use the link I am taking apart. They work wonders some times, other times they are a pain in the keester.
    Howdy
