Results 1 to 10 of 10
Thread: How many disc are normally ran in honda350x suptrapp??
    missouri
    127
    Some in fo please..thanx guys
    Columbia
    5,131
    Rumor has it 6 discs for stock set-up.
    missouri
    127
    mine has been jetted and k&n filter...should i run atleast .2 mor disc, to get better performance or do i take out 2 ,i am not familier with supetrapp always ran DG so for give me if i am a little slow..thanx
    Columbia
    5,131
    From what I know, 6 is for stock bore, stock port layout, stock carb setup. Garry Crum has 8 on his, but also has a big bore kit. Go out and run it. Play with the amount of discs you havev in it. You will find the right number if you play with it for a bit. This would also do a lot better in the Trikeslyvania forum, you will get more thoughts on this. I would start at 6 though.
    Phoenix, AZ.
    6,719
    I run 12 on mine. Used to run 18 on a modded 200x.
    Michigan UP
    1,005
    You must have a tow truck type of a boom off the back to hold all of them up. lol
    RamsesRibb's Avatar
    RamsesRibb is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Louisiana
    316
    the number of discs depend on whether it's a 3in or 4in tip
    Previously known as HighFlying101 since 2003
    I changed my email and lost my password
    Current: '85 Tri-Z , '83 250r , '86 Tecate, '80 ATC110
    Prior: '85 FTZ ATC350X, '85 Tri-Z, '85 ATC200X w/ Bassani exhaust, '83 Big Red, '81 ATC185S, '79 ATC110
    http://www.ipetitions.com/petition/tpctrikes/
    Fresno Ca
    2,695
    Im with dammit, when i even have the endcap on, i run 18-22.
    missouri
    127
    well thanx for all the input fellas will just experiment with it..and its a 4inch tip
    I've got about 16 on there and an open airbox.
