Results 16 to 30 of 39
Thread: FINALLY got a 250r deal of the CENTURY (HUGE pics)(LONG post)
    plymouth,il
    1,231
    I doubt if it's the same one but it might be it was sold at lowdermans auction in macomb,il thats over two hours away from springfield it's possible I guess.
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
    Nov 2009
    1,147
    Probably not, who would be asking $1900 and then sell it at auction for $500. Just so you know I went up 2 sizes on my jets for winter and now it starts great.
    plymouth,il
    1,231
    well I don't have any jets for it I'm going to try to take it apart today and clean it just so I know it's clean and I'll change the fuel out. we'll see how far I get I've never take on of these carbs apart before.
    1984 200es big red
    1976 suzuki rm125
    Nov 2009
    1,147
    Pretty simple, if you have taken apart any motorcycle or ATV carbs they are all pretty similar. If you have a good aftermarket sled or motorcycle shop you should be able to bring in your jets while they are out, they can sell you a couple larger sizes. Jets only run a couple bucks each.
    plymouth,il
    1,231
    the nearest ones an about an hour away so It will be awile before I'm ion town.
    1984 200es big red
    1976 suzuki rm125
    ebecme01's Avatar
    ebecme01 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2005
    NW Ohio
    186
    I can provide close-ups of whatever areas you need to see OEM parts/locations for
    plymouth,il
    1,231
    sweet I was wondering what the tail light and head light assemblys looked like also the parking brake and front brake. Thanks
    1984 200es big red
    1976 suzuki rm125
    Dec 2006
    St. John's Newfoundland
    1,587
    Really good deal. Shes a keeper. I would just pop the head off and see what size piston she is on and what shape its in just for kicks. Then again that cost me a pile for what I found on my 81R.
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    plymouth,il
    1,231
    I just got done cleaning the carb it had some crap in the bottom of the bowl it must have been sitting a while. I forgot to pull the plug to see if it's any good. It's 30 out now I tryed kicking it over for a while and it still wouldn't fire so I'll check tomorrow about the plug but if that ain't it I'll have to call in the calvary. On a better note I now know it has carbon fiber reeds.
    1984 200es big red
    1976 suzuki rm125
    OK
    5,450
    Are you getting a spark? Pull the spark plug put it in the boot, holding the boot, ground the end of the electrode to a cylinder head nut and crank the kickstarter with the other hand. You should see a spark arcing from the nut to the spark plug. Make sure you are holding on to the rubber part of the boot or it will shock you.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    plymouth,il
    1,231
    Thats what I said I was going to check I'm to exited to wait till morning I'll do it after I eat dinner I worked strait through it earlier. this is an addiction i'm telling you
    1984 200es big red
    1976 suzuki rm125
    plymouth,il
    1,231
    ok just pulled the spark plug it is a ngk R BPR4ES from what I've seen thats not the right plug its supposed to have a BR8ES. What does this mean as I know nothing about this engines history or the person who owned it. If it has a big bore kit on it does it use that spark plug? Maybe the guy just threw it in there for the heck of it I don't know.
    1984 200es big red
    1976 suzuki rm125
    ebecme01's Avatar
    Sep 2005
    NW Ohio
    186
    brake and light shots
    not sure what you are looking for on the parking brake. its the same as a 83-85 200X. all of the brake components are the same as the 200X except the lines I think
    Attached Thumbnails Attached Thumbnails smaller3.jpg   smaller4.jpg   smaller1.jpg   smaller2.jpg
    plymouth,il
    1,231
    sweet thanks hey do you know if the grab bar is the same as a 200x
    1984 200es big red
    1976 suzuki rm125
  15. #30
    ebecme01's Avatar
    Sep 2005
    NW Ohio
    186
    Im not sure. I can go look though. they aren't the same. the 250R grab bar doesnt have the round collars at the mounting holes, its just flat
