Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: Maximum RPM
    Williams Lake, British Columbia
    89
    Maximum RPM
    I wanted to know what the max RPM's are for a YTM200 if anyone knows, i rev it up sometimes and I need to know what my max RPM before I blow my motor 10 miles form home. if there's a link to a specs sheet with his info I could use that as well. Thanks.
    3 wheels, dusty trails, gasoline and good times.
    Feb 2009
    michigan
    2,387
    when it blows up(lets loose) youve reached max rpm's.there is no set number.too many factors to consider.
    1985 ATC 250R
    . Team Red Trike
    osoyoos bc canada
    1,057
    a ytm is a trail trike not a race trike and reving the crap out of it will slowly kill it
    89
    Quote Originally Posted by bcredneck View Post
    Well, this is for safety's sake, i'm not revving the crap out of it, i don't want to shift by ear all the time and find out one day that i did one too high. I do race it on occasion for fun but im never redlining it, an'd im not power shifting it either, it's just because i'm going to put a tach on it and I wanted to know what the max was, mostly because i heard of streetbikes with a high redline and i didn't want to find out what mine was the hard way. so yeah. It's easier to talk to me in person, if you can keep up :P
    Honestly, if you can't figure it out, you should probably get a Scrambler or something. It ain't rocket science.
    89
    Thanks for the helpful reply. If I can't figure it out, I'll ask for information on 3WW. Love the educated opinion though.
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    IMO you wont blow it by simply reving it to the redline to shift. Just dont hold it there! I'm racing my SX hardcore in winter and the motor did not lose any compression at all. All you need to remember is not rev it to the sky when its cold or for a long period and make sure you got fresh oil.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Michigan UP
    1,005
    I'm with Fabio, if you don't know when to shift then it is time for an automatic. When the noise and vibration starts to drive you crazy it's time for another gear.
    Aug 2007
    Moab, UT
    1,807
    When your valves start to float and the engine loses power and starts to burble, you've hit max rpm.
    Crest California
    3,014
    If you feel that your RPM's are a bit high, then shift. If they're too low, and you're not going anywhere fast, or its bogging down, then down-shift.
    LED obsessed
    2015 Yamaha FJ-09
    Mar 2007
    Texas
    5,045
    if it blows up, you know you went to high.
    ________________
    https://www.mikesatvfix.com
    Dec 2005
    Wisconsin
    1,141
    You wont hurt the ytm. I have been beating on mine for years and never had a problem, it's seen a lot of WOT for long periods of time. Run good oil in it and giver hell.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    89
    Quote Originally Posted by WIkid500 View Post
    well the problem is i have no money to replace anything in it lol, so if I do blow it up, it's gonna kill the rest of my year
    Crest California
    3,014
    It's just like with a car, you listen to the RPMs, and you can kind of guess when to shift, or when it will shift.
    LED obsessed
    2015 Yamaha FJ-09
    Dec 2005
    Wisconsin
    1,141
    Quote Originally Posted by Backfire View Post
    But like I said.... You can't kill them. I have sank mine twice to the point it stops running, tip her up on end drain it out pull start and keep riding. The most work it used to see was when we would ice ride and it was Wide open for 4 hours at a time. Ride it. And hey if you don't want to wind it up don't. Simple.
    1985 Honda 200x...
