Results 1 to 9 of 9
Thread: carb/cam recomendation
    pcs's Avatar
    pcs is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2011
    yuma, az
    465
    im in the process of building up my 200x motor, so far i have the following
    wiseco 10.25 c/r
    s/s valves
    ported head
    r/d hi perf valve springs w/ ti hardware
    cobra exh
    i see plenty of knock off xr200 carbs on flea bay and from what ive read is that they are bigger than the oem and bolt up. ive read that those faux kiehn carbs work well but do real kiehn jets work with them?
    also, any recommendation for a cam, dunes and hill climbing.
    Team Blue: 85 Tri-z 250: under the knife
    Team Red: 87 Trx250r 01Cr80 15 CBR600RR
    Team Yellow: 06 Ltr450 11 Hayabusa
    earth
    141
    i have one of these fake keihin carbs. it came with my wifes 200c gio quad. yah one of those four wheel things. this bike was very hard to start, did not idle well and and if you stabbed the throttle there was a big lag. anyway to make a long story short i got a different carb for it. just last night i decided to open up the carb. it looks like keihin main jet will interchange but the pilot is a different story. there is a brass insert that prevents the longer keihin pilot from fitting. i think the pilot circuit is the problem with these carbs, no air screw or needle adjustments made a difference to starting and bottom end . so i decided to drill out the brass insert in the pilot location, now a keihin jet drops right in . have not had a chance to try the carb back on the gio we will see what happens and report back.
    Nov 2009
    Okauchee, WI
    555
    I was runnin an xr200 cam for a while in my X. Really seemed to rev higher and pull harder on the top end. Unfortunately there was some bearing schlague on it, so when I rebuilt the top end a couple weeks ago I put a stock cam back in. The power difference was night and day. If you're on a budget the xr200 cam is the way to go.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    i was also thinking about the xr200 cam but cant seem to find one in decent shape =(
    big red
    let us know what happens with your carb test.
    Mar 2007
    Texas
    5,045
    do you want to spend some $ or are you looking for cheapo? if your wanting to spend the $ to do it right, web has an awesome setup.
    stage-3 cam
    web springs
    web retainers
    web hardened rockers ($65 each)
    list goes on.
    if you contact www.theoldone.com (Endyn) is the shop they do CNC valve work and valve seat work on these heads and help improve flow and lot more torque. for $150 they dissamble the head, clean it, work on it, clean again, then reassembly everything. if you have the new parts they can install them, they also are web dealers so you can order everything through them.
    if you want to do it the cheap way, xr200 cam and lapped valves. make sure you repalce the valves as i can assure you they are probebly worn.
    ________________
    https://www.mikesatvfix.com
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    i listed what i already have purchased. my head is already ported with new valves and assembling 200x heads is really easy. i was looking for a xr cam just to get the engine running with something better than stock. after, i can decide what cam to go with. have you ridden a 200x with a stage 3 web? if so, did you like how the engine performed. also, you are right about the valve, they were worn out when i pulled the head apart.
    ametzker's Avatar
    ametzker is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oregon
    170
    Powroll makes some great stuff although a little pricey. The cams did not seem out of range. Here is the link http://www.powroll.com/P_HONDA_XR200.htm
    ametzker's Avatar
    Oregon
    170
    http://www.akunar.com/CARBURETTORS.html I have the older version of this flat slide carb on the top and let me tell you this thing worked great on my 79' Franken bike with a 71' sl100 engine bored to a 150cc+ with a Powroll cam and an Akunar hi comp piston and port work done all by myself. I raced against the Evo 125 2-strokes and took the 125 class championship. I even did well against some modern bikes in an Arean cross race. The engine wasn't a rever but made a ton of power off the bottom right through the midrange. Heres the link to that build
    pcs's Avatar
    Jan 2011
    yuma, az
    465
    nice bike, i found a 28mm round slide mikuni on flea bay for $30. will i need an adapter or will it bolt up?
