Well I just got this 250r and I have been trying to get it running so I took apart the carbureator apart and cleaned it. Didn't notice anything broken at the time but i put it back together and then tried the throttle for the first time and it wouldn't return. I figured I put the carb back together wrong I though I didn't have the throttle valve seated right (have the pin in the little slot)extremely technical terms here. Well I figured out the throttle valve was just twisting when I turned the throttle because the little pin is broke or has been filed off but some idiot. I need to know if this pin is replaceable and where to get it or if I'm just screwed.
