durablue 250r axle removal help
Well, I am having problems removing the durablue 2+2 axle from my 1985 250r.
The first problem was removing the collar on the right side. The manual said to basically unscrew the outer nut and the collar should pop off, right? Well it didn’t. The threads would jump, skip, not catch, and it would not pop the collar off. There was just not enough force to pop it off.
Here is a picture of the collar. I had to cut it off :-(
For future reference, how do I get that collar off without cutting it?
Here is the problem I am at now. There is a little lip on the axle that held the collar on. Well, that lip is preventing me from taking the outer nut, inner nut, and disc brake off. How do I take these things off? I cannot simply pull them off like I thought I would be able too.
You can see the lips in the above two pictures.
The axle is supposed to come out of the left side, right?? The manual says it is suppose to (or that is how I read it) but my dad will not stop arguing with me. He is convinced that it should come out of the right side.
Thanks for the help!
My Rides:
1985 ATC 250r
1989 Suzuki LT-160
