Results 1 to 12 of 12
Thread: How do you know if your valves are bad?
    redskinman's Avatar
    redskinman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2010
    Cypress,Tx
    378
    What do your valves look like when their bad? What are the symptoms of bad valves? Im guessing low compression,anything else?
    Heres a pic of a head I just got off ebay,what do I look for on the valves to see if theyre good or bad? The carbon buildup left on these does not want to come off,can I use a flexshaft with a soft wire brush to get it off or is that a nono?
    thanks
    82 250r-SOLD
    85 200x-SOLD
    85 Odyssey fl350-SOLD
    1989 Honda Pilot FL400
    1985 Yamaha 225dx
    Dec 2007
    Quebec,Canada
    1,014
    easy test,install a spark plug and fill the combustion chamber with brake cleaner or gas,check for leaking in intake and exhaust port
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    And when the seats and valve contact area look ed...... they'll have raised edges rather than being perfectly flat and angular.
    The wire wheelin all over the perimeter kinda says "I just got brushed!! I need a rebuild......"
    oregon
    668
    doesnt it blow up if you put too much gas into the cylinder at once? i was always told if you fill the cyclinder with gas and try to start it the whole thing will catch on fire.
    This is my trike.
    There are many like it, but this one is mine.
    My trike is my best friend.
    It is my life. I must master it, as I must master my life.
    Without me my trike is useless.
    Without my trike, I am useless.
    I must roost faster than my enemy who is trying to beat me to the finish.
    I must beat him before he beats me.
    Before God I swear this creed.
    My trike and myself are defenders of track.
    We are the masters of keeping quads the losers.
    So be it ... until there is no quad left.
    Pacific NW
    4,255
    x2 on what dc said
    Valves are cut at a degree or 2 off from the seats so there should be a perfect line where they contact. Specs are in the book, no doubt.
    If it was mine? x2 on atc500x too.
    if it won't leak a small molecular weight solvent, it will prob run with no more concern.
    If you are comfortable removing the valve springs, there is a blue dye you can use to see where the valves touch the seats and hopefully see a perfect sealing line. but again, if it doesn't leak, it'll prob run.
    If the seats are ed or buried, almost any machine shop can dress them up. If the guides are a little sloppy, they can be knurled instead or replaced sometimes. With the springs off, you can check for an axial side wobble.
    If the carbon esthetics bother you, maybe some oven cleaner as long as it doesn't touch any rubber valve stem seals, if it has them.
    ok, now why do you have a new head in the first place?
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    Quote Originally Posted by portland250r View Post
    no if you put to much it wont start because it would be flooded then lol, if you put a little gas the bike will kick right away and run...
    Pacific NW
    4,255
    I think atc500x meant to fill the head only with solvent, like just the way we see them.
    spark plug in, prop them level, fill with solvent and see if it leaks past the valves beFORE he puts the head back on.
    redskinman's Avatar
    Dec 2010
    Cypress,Tx
    378
    Quote Originally Posted by drjoe171 View Post
    I bought an engine that both the cylinder head exhaust mounting bolts were thouroghly screwed up.Got a good price on this head,at least i thought it was a good price,30 bucks shipped.
    I dont see how anybody makes money parting out a 200x,there are way too many pages of parts for them on ebay.
    82 250r-SOLD
    85 200x-SOLD
    1985 Yamaha 225dx
    Dec 2007
    Quebec,Canada
    1,014
    Yes dont fill the cylinder!!!!
    Fill only the head before installing on the motor
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    I always trusted the gas method until one KX 250F didn't leak yet had low compression after I rebuilt it. I sent the head/valves out and they were ed; Now I remove them and check them out.......
    Nov 2010
    Warwick, RI
    66
    In regards to cleaning the carbon deposits, I just cleaned mine the other day using mineral spirits and a piece of fine steel wool. It worked great. I just soaked the head in my parts washer first. It will take a little muscle to remove it all. For the tough to reach areas, you can purchase a siphon-type sandblaster (~$25 on Amazon) and use baking soda for the abrasive. Water will dissolve any baking soda left in the head (a little tip I got from ametzker).
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    Quote Originally Posted by redskinman View Post
    thanks
    Someone has been a bit aggressive with a sander or rotary wire brush there! That head may need refacing to make sure the head gasket seals properly.
    You really have to take the valves out and inspect them. Should be a clean line about 2mm wide on the valve and on the seat.
    To clean the valves once they are out, put them in a drill with the drill in a vise, spin them up but not too fast and use fine emery tape on the face and under the head to remove the carbon. If the seats are okay don't touch them. DO NOT TOUCH THE STEMS WITH THE EMERY (the bit that goes into the valve guide). And be careful not to damage the stems in the drill chuck.
    Custodian of:-
    85 Tri Z - need rear plastics to go with Mosh seat cover
    83 200x - engine being rebuilt but lodging with a friend
    85 250r - also lodging with a friend until I have a new shed
    ....and a different kind of Z
