Thread: 200x trouble
    Jan 2011
    WI
    134
    200x trouble
    so i got a nice 1985 200x from a neighbor down the road. he bored it 10 over, mild cam and i put a dg exhaust on it. its in really good shape and i only paid 500 buck for it. now the problem is that the kick start wont catch. he didnt want to with it is why he sold it cheap. the gears on the kick starter just inside the cover are perfect and it isnt slipping on the shaft. Any ideas what in the hell it is?
    Lauderdale County, Alabama
    2,029
    Where the kicker itself bolts on to the shaft, the splines might be wore down, not stripped completely, enough to hold, but not enough to catch when downforce is applied. Check your Splines! First gen X's were notorious for kicker issues.
    Leonardtown, MD
    594
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Jan 2011
    WI
    134
    my little brothers was doing the same thing but less and mainly when it was cold out so we have his apart now, shes getting a new heart . the splines are good and all the gears seem to be soild. the little compression gear seems to be really easy to push together, so were gunna try and find one online. ill keep you all posted. Thanks for the help
    1985 70
    1985 200x
    1985 200x hot shot
    1985 200x part trike
    1983 185s
    1993 fourtrax "whoretrax" everyones had a ride
    1967 suzuki hustler 250 2 stroke
    2004 buell blast 500
    Dec 2005
    Wisconsin
    1,141
    Looks like you get to split some cases and go digging. The Kicker assembly is inside the transmission of these things, thats why everyone bitches about the 200x. Read up on the stronger spring you can get for it and back cutting the teeth on the kicker gears so they have a positive engagement that wont slip.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
