Results 1 to 12 of 12
Thread: --4 SNOW Tires-- Tell me your experience with them.
    Plattsburgh, NY
    2,311
    I am curious how well the 4-snow tires work. If u have them and use them or have before tell me what u think. How they go through all levels of snow, how they r on ice and if u have other tires that u have found work better. Would like to hear opinions good or bad. Thanks guys.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Dec 2007
    Quebec,Canada
    1,014
    4 snow are simply the best snow tire.Impossible to stop.I have them on my 500x,I can ride in powder snow up to 24 inch easy in third gear.They are also excelent in sand,but will last longer in snow due to the soft compound.By a set and try it,you will not be disapointed
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    bigred44's Avatar
    bigred44 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    Ithaca Ny
    361
    Great tires but be careful with the side walls as they are only a 2 ply tire. Also not sure how well they would work on an underpowered machine.
    '84 ATC 110
    '84 200x
    '85 350x
    '86 125m
    '03 Shadow ACE 750
    '05 Brute Force 650
    Tionesta, PA
    5,747
    I bought a set for the wife to use in the dunes last year - they were OK there - but upon arriving back home to deep snow - I was seriously amazed at how well they do in snow up to about 18".
    These tires are nothing short of amazing in my opinion!
    Plattsburgh, NY
    2,311
    sounds good, i just bought a pair on a TRX450R forum. i cant wait to try it out on my 350X. the rims i am putting the 4-snows on also have the FL350 Odyssey rear bolt pattern. so that should be a lot of fun to drift and blow donuts with.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    they are great if you have enough power to make them spin fast. On my SX, I'm having hard time putting it in 3rd in deep snow but once the engine get some rpms, they just grip and go through the snow. I wouldn't recommend them on a small trike since you need to make them spin to get traction.
    I can get through a lot more snow with these even if I cant make them spin but I dont get any speed. They just crawl.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Aug 2009
    Gold Hill, OR
    594
    I run pro wedge II's backwards in the sand. (the original 4 snows) They are awesome for non suspended trikes. The bubble like tires give that needed cushion.
    When Three Wheelers Attack Productions:
    http://youtu.be/Bh_cvtxz7VQ When 3 wheelers attack
    http://youtu.be/KFONPvn8bzU When 3 wheelers attack: Part 2 (in HD, latest video)
    US-90 Video (now in HD on youtube!)
    "three wheelers don't kill people..... I kill people"
    Plattsburgh, NY
    2,311
    So the tires actually r made to balloon up when spinning? They really must be soft.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    earth
    141
    i would think they are like a drag slick. as they are spun or increase in rpm they grow narrower and taller.
    Jan 2011
    Upper pennisula of Michigan
    55
    http://www.youtube.com/user/tordeur4x4 he has them.
    he's on the forum as "tordeur"
    Quote Originally Posted by Cave Rider View Post
    POLARIS- IS AN ACRONYM FOR "People Often Learn About Reliability Issues Soon" or " Pull Over Loser A Race Is Starting" jkjkjk !!! no im not,or am i
    Mar 2005
    overton, PA
    5,257
    flat out simple th best tire ive seen int h snow. i had a 400 kodiak with chains on all4 tires that strugled more then freak fix and killers 250r's with 4 snows
    ailll1's Avatar
    Dec 2009
    Québec
    405
    Here's what Maxxis say about their tire:
    ■Tire diameter expands up to 40% during acceleration for additional traction and ground clearance.
    ■Reversible tread design offers optimum traction: scoop for snow and backside for increased contact surface on ice
    ■Special soft compound stays flexible in cold weather for amazing grip and the smoothest ride ever!
    ■Drag racer’s first choice on ice, snow and sand
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
