So, I went to get the 70 out and the back wheels won't turn properly, 1/2 a turn backwards but locked solid forwards, probably the brakes binding.
Tried backing off the adjuster, no difference. Ok, just need to pop the drum off and have a look. Removed the rh wheel and hub, can't shift the axle tube. Tried tapping, heating, and combinations of the two, no go. Anyway, the lh tube turns so I'll start the other side and slide the whole axle out.
Took off the lh wheel, removed the hubnut and the nut took most of the thread off the end of the shaft, then the hub won't come off! Tried a puller, then heat and abut it won't budge.
The back end could do with new bearings while I'm in the process of stripping it, but if I can't salvage this axle shaft are they difficult to obtain?
As they say "When you're up to your butt in aligators, it's difficult to belive the original plan was to drain the swamp!"
but it won't budge.
Trikefest UK '08 survivor!
