Results 1 to 7 of 7
Thread: has anybody used heli-coils before? need help
    missouri
    127
    i have 3 threads stripped on my cylinder head and not sure how to put heli-coils in..some tips please so i can do it right,thanx
    osoyoos bc canada
    1,057
    drilled out my spark plug hole put the coil around the plug theads and screwed it in
    Jun 2006
    Ohio
    2,294
    1981 ATC 70
    1978 ATC 90
    1985 ATC 250R
    www.cosmicquads.com
    Most of the time if they are stripped out already you won't even need the helicoil drill. Put lots of grease on the proper helicoil tap and tap a little at a time , then remove it, clean it and regrease it. Continue till your done.
    I don't even buy the installation tool, only the tap. I just wind them up, keep slight downward pressure and use a screwdriver on the tang until you are just below the original top surface. Make certain it does not skip threads or remove the helicoil.
    The tough part with an oil plug or spark plug is getting the "break off" tang once installed. I use a long very thin pair of needle nose to pull it up and out.
    I have done hundreds of helicoils, never had one back out or fail and they are used on every NASA shuttle..............
    missouri
    127
    so iguess this happens ofthen with alumunum heads?...thanx for help guys it takes a lot of pressure off me
    Apr 2008
    NW, IND.
    842
    I'd go with stainless. I had to turn mine down for proper fit.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    missouri
    127
    She is fixed..now on to other problems.
