Results 1 to 8 of 8
Thread: Is a 200x an interference motor?
    booblinker's Avatar
    booblinker is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2007
    WAshington, mi
    301
    Threw the timing chain on a 200x, fixed the timing chain, and still no compression, like 0 psi, did I bend a valve, or out a hole in the piston possibly?
    -84 Honda ATC 200s("Rustored")
    -85 Honda 250SX
    -85 Honda 250ES
    -2017 CRf1000L (all ADVed out?
    Nov 2006
    southern oregon
    2,338
    yes.. .
    2-stroke lover
    ATCrider42 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Iowa
    227
    what exactly do you mean "threw" the chain? Like it snapped apart while you were riding it? You should be a litle more specific if you want some good advice. Also you need to post some pics of your engine. romoving just your cylinder head isn't too tough. Just read the manual and remove the head and take a look. Most likely though yes you bent your valves and will need a new piston and head rebuilt.
    yes......................
    booblinker's Avatar
    Aug 2007
    WAshington, mi
    301
    Chain came off, put a new chain on and still no compression, chain came off due to the spring on the bottom of the case being bent, and not keeping the timing chain tight, I am assuming something really bad happened and caused all of this. It is actually by buddies motor, I tried to get him to take it all the way apart since he already had the timing chain and cam off, but he though it was fine, guess he has to take the motor back out and see what other damage he did.
    -85 Honda 250SX
    -85 Honda 250ES
    Sep 2007
    100mi west of Chicago
    3,582
    Only way to know for sure is to take it apart. Probably at least bent one or both valves, who knows what other carnage occurred.
    Rob
    ontario
    1,131
    take the rocker covers off see if there is space between the valve and rocker arm if there is alot os space then you bent a valve if there is no space then there is other problems. hop this helps.
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Mar 2007
    Texas
    5,045
    I will bet $ the valves are bent and you'll be lucky if the piston dosnt; have a very big dent in it from hitting the valves. Also typically wheny ou bend valves on these heads like that, you end up cacking the guides. so check them as well.
    ________________
    https://www.mikesatvfix.com
