Results 1 to 7 of 7
Thread: oil leak
    Jan 2011
    Upper pennisula of Michigan
    55
    oil leak
    last year when I was getting my trike out for the summer my friend was going to change the oil while I went and got gas, but when I got back it turned out he had turned the bolt in the wrong direction and stripped most of the threads and now it leaks oil. Any suggestions on how to fix this or atleast slow down the leaking process?
    Quote Originally Posted by Cave Rider View Post
    POLARIS- IS AN ACRONYM FOR "People Often Learn About Reliability Issues Soon" or " Pull Over Loser A Race Is Starting" jkjkjk !!! no im not,or am i
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    Tap new threads. Flush it at least once before running it to get shreds out.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Pacific NW
    4,255
    oops. Another reason I hide my tools.
    Depending on the thickness of your case castings, and how many, if any threads are left. you can look into oversized 'self stripping', I mean self tapping threads. Take the old one to an autoparts store. and maybe even get a longer one.
    Or do it right and buy a tap and plug and read the directions.
    I put one in with plumbers teflon tape wrapped a few times around the plug and it's still holding. but whoever rides it better be aware enough if it falls out.
    I had a real bad one on a beater 'disposable trike and glued it in and changed the oil by pouring it out the fill tube.
    Sorry for your loss but I KNOW how you feel.
    More than 1/2 the people who get near my stuff are unqualified and dangerous.
    Michigan UP
    1,005
    Give me a call and I will give you a hand fixing it.
    missouri
    127
    i did that with my 250 bigred, i just took plugg down to napa auto parts he gave me a heli plug which will replace the old plug..EASY FIX..just put it in and take time re threading.keep baking out a few times to keep it clean..and when done put in and off to the trails ..the lug was like 3$ bucks.
    Silverado's Avatar
    Silverado is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Whitby
    331
    Hahah poured it out the Fill tube ! That Sounds hilarious ! I know it would work, but just funny having to do it that way.
    1985 250sx (Lemon)
    1985 250sx (Ruby)
    1985 250sx (Garnet)
    1985 200m (Hunter)
    Nov 2010
    Oshawa, On, Canada
    2,123
    Quote Originally Posted by Silverado View Post
    Time to do an oil change, let me just knock my bike on its side real quick. haha
