Results 1 to 13 of 13
Thread: extending a 350x swingarm ????
    Dec 2006
    Chaple Hill, North Carolina
    198
    I am going to be extending the swingarm on my 86 350x . I know when I measured it up to get a idea of the size of metal i will be needing was around 2 1/8" x 1 1/8". I have called around a little bit and looks like I am having a hard time finding this size??? Dose anyone know where I could find it or could I get by with some 2"x1"?
    danimal95's Avatar
    danimal95 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    il
    289
    2x1 may just slide right inside of the factory metal,which would be alright,but i would box it in with soem flat stock afterwards.try mcmaster carr for the steel. mcmaster.com
    2003 banshee ported jugs,piped,yad-ah,yad-ah
    1986 tecate KX5 swap
    1986 350X(cammed ported piped)sold
    1985 250R(310 klemm pipe)
    1985 atc70 x 2
    other toys
    1995 mustang cobra 6 speed twin turbo
    1075 rwhp 963 rwtq
    9.25@156mph
    1992 GMC typhoon 402c.i. LS1
    4L80E AWD twin turbo a/c power steering and cruise
    963 AWHP
    9.40 @ 147 on 4 drag radials
    Dec 2006
    198
    I was thinking the same but i haven't cut it yet so i didn't know the thickness of the walls. so i guess i will have to cut and see if i can get some 2x1 maybe to slide in.
    I use angle iron and make my own box, whatever size I need.
    Dec 2006
    198
    I am know master fab guy i get by lol so what dose angle iron mean lol???
    osoyoos bc canada
    1,057
    the stuff they make bed frames from and it would look like crap and have 0 strenth use tubeing
    osoyoos bc canada
    1,057
    if you were a pro @$$ welder you might be able to pull it off
    Apr 2006
    SE CA Dez in the sandbox
    900
    there was a thread somewhere not too long ago and someone posted images of how he took two swingers cut them in different places and welded the front of one to the rear of the other for a 4-5" longer swingarm. I'm trying to locate that thread. When I find it I'll post the pics.
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    There's nothing wrong with using angle iron, I'm sure Fabio isn't using bed rails and WTF does the welder have to do with it if the steel is soooo inferior??
    You may be able to get something and cut it down on the top or side making it a "U".
    I love Mcmaster but they aren't my steel and Al choice - try Speedymetals, excellent service, every size imaginable and shipped fast. A right angle grinder is your best friend for this type of work and a good Mig welder.
    The swinger that was recently posted was the guy building the stroker 350X with a 250R front end; I just can't recall his name at the moment.......... But his thread can't be more than a few pages back. He angle cut his - more surface area to weld = good.
    Nov 2006
    southern oregon
    2,338
    a jig is very helpful too
    2-stroke lover
    Quote Originally Posted by bcredneck View Post
    Ummm, wrong again redneck. I'm sure you're used to that by now.
    There is a big difference between bedrails and angle iron. My swinger has held up for about five years now and if you look at my profile pic you will know I do not take it easy. You're the genius that tries to build things out of bedrails, not me. BTW, how's that hardtail 399 running?
    TECATEMATT, if you look in this thread you will see how Dan and I went about extending his swingarm. For his we added a little more internal strength with some square stock. I don't know what size it was, but it was probably about 1/2 x 1/2. We didn't do this because of any issues I had with my swing arm (which was extended first), we did it because he had the material lying around so why the f**k not?
    http://www.3wheelerworld.com/showthr...ild&highlight=
    Michigan UP
    1,005
    I just checked out the Tecate swinger and it looks great, must have used the rails from a king sized bed for that.
    Dec 2006
    198
    haha thanks for the tips yall i guess i am going to have to cut down the swinger and test fit with some metals to see what fits best.
