Thread: 250r front end swap..
    blkstangman88's Avatar
    blkstangman88 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    marysville
    282
    Is there a differance between the offsets of the front tires of the 350x and the 250r? i went to mount my 350x front tire on my 250r forks and found out when i tighten the shaft down the studs for the rotor hit the fork.
    its like i need a 1/4in spacer on this side of the shaft. you can see i dont have it tightened down so i can still roll the trike around
    Miami,Fla.(305)
    808
    If youre using the 350x hub on the 250R -then thats your problem cause theyre slightly different but look identical.
    Nov 2010
    marysville
    282
    well damnit lol will the 250r hub fit the 350x rim?
    Miami,Fla.(305)
    808
    yes....it will.
    I had to use the 250R front wheel with SS collars and a SS bolt made by Ronnie............
