Results 1 to 8 of 8
Thread: How to add/change fork oil in 350x?
    Oct 2006
    Titusville, FL.
    631
    How is it done? My forks are extremly soft, It might not have any oil in there? All I could find in my manual is it says to use ATF? Automatic Transmission Fluid?
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    Yes, automatic transmission fluid works well. You can also put oil especially made for forks with different weighs, depending on your weigh and how stiff you want them to be.
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    bigbadktm's Avatar
    bigbadktm is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    San Diego, CA
    437
    atf is around 7wt you can go up to 20wt i believe
    there should be bolts at the bottom of the forks for draining and then you unscrew the caps (take all preload out of the forks) and fill it with the prescribed amout of fluid. if you have a ratio rite cup it is graduated with cc's oz's and all that so that you can measure it easily
    hope that helps
    1985 250R
    FMF pipe and silencer, K&N, 4" extended swingarm
    Oct 2006
    Titusville, FL.
    631
    so you drain it out the bottom, and fill it from the top?
    bigbadktm's Avatar
    San Diego, CA
    437
    you got it toyota, i have just replaced the fork seals in mine and havent filled em yet due to time constraints but the 85 R calls for 400cc of fluid per fork. yours is probably different as the 86 R takes a different amount as well.
    hopefully your forks had oil in them to begin with, i made a desert trip and found out later that the PO had drained the fluid out and it made for a crappy weekend
    1985 250R
    350xorbust is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2013
    Dryden ON
    196
    Quote Originally Posted by bigbadktm View Post
    So then (sorry to hack) what is the air valve stems for, at the top of the fork...am I supposed to add compressed air to them too?
    fallguy666 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2013
    athens jawga
    201
    You can. but no note than 10psi.you'd be surprised at how stiff they will be with that little bit of air.the bleeders were also used to purge unwanted air after a race
    Feb 2013
    Dryden ON
    196
    aahhh...thanx for trhe heads up...
