Results 1 to 10 of 10
Thread: should I rebuild
    ontario
    1,131
    should I rebuild
    hello guys I'am at a stand still with my 200m engine it is in a 200x right now and runnes good was lots of power starts up in -20 first pull, burns oil 1L for every 8hours of trailing riding. The bad thing is that it only was 80psi compression and when I put oil in the cyclinder it gos up to 100psi.
    Should I rebuild it or just see how long it goes, rings are $40 and a topend gasket is $30 so it doesnt cost alot. Also will the cyclinder off my 200x work on the 200m? thanks Aaron
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    here
    1,336
    The top end of the 200x is a direct bolt on the 200m motor. (If I'm wrong correct me guys). And works excellent. If that whole top end is good off you x motor, put it on. What was wrong with the x motor? Lots of guys have built up the 200 motor with the 2oox top end. How'd you like the auto though? I really like my daughters. And the 200x is so much funner with a twist throttle, even with the 200s motor.
    ontario
    1,131
    the tranny is going on the x engine an I worn the splines off the out putt shaft last season, dame cheap sproket. I was thinking about putting the hole topend on the M but I may have to pull start it, and the X head doesnt have a decompresser so it would be a to start. I remeber having a 200es and it was a to pull over with out the decompresser. lol I was like 8 so I may be wrong. I dont really like the hole auto becasue it shits the other way all down, and I miss not having a clutch anymore other then that it still goes pretty good
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    New Brunswick, Canada
    60
    I would definitely search for an xr200 tranny or whole engine and use that, I bought one for 60$ and threw my 200x top end on it.
    ontario
    1,131
    thats ather way to go. isnt the xr a 6speed what about the kick start the xr kicks back doesnt?
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    ontario
    1,131
    I looked on ebay and all I could find anything usabile on a cheap budget iam just going to get ring and a gasket kit and put my x topend on the m right now. iam trying to save you enought money to get my truck on the road and iam only a few thoundred dollar away so i dont want blow it on my trike
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    muskoka ontario canada
    27
    Rebuild it.just get the parts and go at it!
    Silverado's Avatar
    Silverado is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Whitby
    331
    You could always MacGyver it and fix it will things you find around the kitchen.
    empty coup can, some oil, half of a soda can, a bunch of tape and a and your set !
    1985 250sx (Lemon)
    1985 250sx (Ruby)
    1985 250sx (Garnet)
    1985 200m (Hunter)
    nova scotia
    125
    what i would do is use the 200x cylinder they have larger cooling fins but if you use electric start you need to grind some of the fins down so it fits. and use the 200m head so you have a decomp and switch the cam because the 200x cam is an up grade for the 200m motor
    ontario
    1,131
    the x was bigger cooling fins? I have never though of that lol, iam going to see what the m cylinder looks like if it is clean and std bord iam just going to put the x pitson rings and cam into the m, as when I do get money to fix the x I will be replaceing all of theso parts. Thanks for the info guys iam going to clean off a bench in the shop today and start on the x
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
