I have a 42 pilot and a 210 main in my 350x with 400ex carburetor. It cuts out a little at WOT, but i would rather run a little rich then lean.
I had a 45 pilot in my 350x and i could not for the life of me kick it over.
Just fool around with the air/fuel screw until it will kick over in a few kicks.
This is what i did.
I would screw the air/fuel screw in until it was fully seated, then i would turn it out in 1/4 or 1/2 increments. I would then turn the choke on, and kick it 10 times. Then i would turn the choke off and kick it 10 times. If it would not start, i would screw the air/fuel screw out another 1/4 or 1/2 of a turn.
once the bike would kick over, i would continue to screw the air/fuel screw out until it would not kick over again. then i would screw it back in about 1/2 of a turn.
This is how i got the 400ex carb to start on the 350x. I highly suggest that once you do this, you do a WOT plug chop and mid range plug chop to see if your running lean anywhere. If your running lean at WOT, up the main pilot, if your running lean at mid range, up the pilot.
I dont know if this is really the proper way to jet, but i can easily start my 350x in one or two kicks, and its not running lean at WOT. (still need to check mid range)
My Rides:
1985 ATC 250r
1989 Suzuki LT-160
