Results 1 to 15 of 21
Thread: 350X: FL to PA won't start
    camoweasel's Avatar
    camoweasel is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Pennsylvania
    180
    Just like the title says, I'm once again living in cold PA so now I can not for the life of me get my 350X to start. In FL, I didn't have much trouble starting it but now with the cold winter climate it wil not fire!! My first guess would be the gas. Is FL gas different then PA gas?? I suppose the PA gas would have additives to help with cold starting?? I'm lost. Here is my setup:
    400Ex carb
    190 main
    42 pilot
    air screw 2.5 out (all though I tried at mant different settings but nothing seems to help)
    no airbox lid
    Oct 2007
    Minneapolis mn
    4,067
    Put your airbox lid on it... Its a Honda, so its cold blooded... Lots of choke. My BR is weird, MN cold, and it like full choke for a few spins, then no choke, it will pop, turn the choke back to full, and it will start right up...
    sittinguy's Avatar
    sittinguy is offline Titanium Balls Arm chair racerAt the back of the pack
    Dec 2003
    343
    Why would you leave FL?
    Depending on your altitude. You might have to adjust your carb needle position.
    camoweasel's Avatar
    Oct 2009
    Pennsylvania
    180
    I moved to FL in hopes of finding a job and relocating. Plans didn't work out so now I'm back home in PA. My altitude is about 2200 feet. The needle is set in the middle position. By luck, I did get started yesterday and took it for a ride. It honestly seemed fine to me. I couldn't tell any changes or flat spots anywhere in the powerband. It's just trying to get it started. Today, I kept messing with the fuel screw. I turned it in and out to various positions with and without choke with no success. It seems like it will fire for about 2 revolutions then quit. That and with the temp being colder, there is more resistance when trying to turn the engine with the kicker lever.
    Jan 2011
    mifflinburg
    525
    Lol if your messing with your air/fuel mixture screw prolly needs readjusted.. Where u at in PA? Ride together some time
    camoweasel's Avatar
    Oct 2009
    Pennsylvania
    180
    Quote Originally Posted by Headsup View Post
    Yeah, I pretty much got that figured out?
    Jan 2011
    mifflinburg
    525
    Take her all the way in an back it out 1 1/2 turn to 2 full turns.. should be close.
    camoweasel's Avatar
    Oct 2009
    Pennsylvania
    180
    I did 0.5 turn increaments from 0.5 to 3.5. Nothing seemed to help.
    Nov 2006
    Huffman TX
    891
    Theres a Honda for ya.... my x dose not like cold weather, some days she just simply refuses to crank(that or I just get tired after 10 kicks) and I just say heck with it and jump on the bayou
    TRIKES
    1987 200x -First Trike-
    82 185s-SOLD!
    82 250r-SOLD!
    85 250es -the lil red hulk
    Quote Originally Posted by Midnite_rider View Post
    I like the outlook..... It ran fine before it broke!!!! it was flying before it exploded!!!! it was like new until I tore it up!!!!! LOL She was a virgin until last night??????
    jrsqlc's Avatar
    jrsqlc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Northwest O HI O
    321
    i ran my x in late november with the air box lid off and it ran the best it ever did, i went out during our spell of nice weather and kicked that sucker 20 times before it fired and it didnt want to run from 3/4 on....tempermental hondas
    Aug 2004
    Ab Canada
    4,368
    Try some 0-40W Amsoil in it,,If your leaving it outside in the cold, Might have to Adjust the pilot jet and Fuel screw also.
    1985 Tri-Z-
    Air screw and pilot jet will get it going 1st kick with some trial and error.......
    Nov 2009
    1,147
    A lot of it is figuring out the trick to your machine, my 200X liked to have me pump the hell outta the gas 7-12 times depending on temp, kick it once with full choke, go down to half choke, pump the gas 3 more times and it would fire right up like it should, but it was all in that weird ritual, anything else and it was terrible to start.
    79fordblake's Avatar
    79fordblake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    Wingo, Ky
    278
    In my area around close to 0 degrees is as cold as it ever gets. Summer time or winter time I flip the choke on all the way pull the rope one time and it fires, move the choke to half and it starts. I have been through my carb a thousand times and I am still tinkering with it. I am sure poor quality of gas could be a part of your problem. All the vehicles I drive are carburated so I can tell when I get good gas and when I get bad gas. Most of the time I get bad gas, lol. The only thing I have that runs good on todays crappy gas is my old John Deere tractors.(originally ran on disilate or kerosene)
    1981 Honda 185s
    DG Exhaust, Clamp on Uni Air Filter
    '85 200x carb, 200 Cylinder (SOLD)
    1981 Honda 185s
    Straight Pipe, Uni Air Filter
    200x Carb, 200 cylinder (SOLD)
    1985 Honda 250ES Big Red
    Uni Air Filter
    1986 Honda 250ES Big Red
    Uni Air Filter
    Jan 2011
    mifflinburg
    525
    Alot of people must get Different jets for their machine to work year round. Just change them with the season..
