Thread: xr200 camsaft issue
    Jan 2008
    Cleveland Texas
    305
    xr200 camsaft issue
    Hey guys, finally got the time to assemble my engine. I'm using everything from the base gasket up from a xr200. Everything is fine up to the cam. For some reason the cam bearring will not seperate from the cam shaft. And when it's put in the head, the bearring needs to slide back off the shaft a small bit. Since it does not come off, it causes the bearring not to spin. Any tips?
    Also, will i notice a large power increase? From a worn out engine(around 8:1) to an xr engine with a 1.25:1 piston, larger cam, and bigger carb?
    Thanks guys.
    -Fathers 1985 200X
    pcs's Avatar
    pcs is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2011
    yuma, az
    465
    try warming up the bearing so it can slide off? or maybe have a machine shop press it out. if all else fail, cut it out =)
    Team Blue: 85 Tri-z 250: under the knife
    Team Red: 87 Trx250r 01Cr80 15 CBR600RR
    Team Yellow: 06 Ltr450 11 Hayabusa
    Southern MN
    1,875
    Is the bearring/bushing siezed onto the cam? Of so, that is not good news, and I would be leary about rinning that cam in an engine of mine. I suppose the correct way to remove it if it is siezed is to use the appropriate puller.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Jan 2008
    Cleveland Texas
    305
    Yeah i think your right. I guess i'll just use the normal cam for now. Thanks for the input.
    -Fathers 1985 200X
    The Open Road
    4,736
    even if you could press it back off, the tiniest scratch on the cam end will cause premature seizure later on even with a new bearing so I`m agreeing with YamahaRules
    something is wrong and I wouldn`t use it....could very well destroy the entire topend
