I have a 97 thundercat I sucked a reed the v force3 when that happened it broke the reed cage . Now I have to by boysen rage cages my question is if I can use the modified stock intake boots with my rage cages and what would happen if I did?
Well, i just looked up their site and the Rage Cages for your T-Cat. My guess is you can use your stock carb boots. I just installed some 1st gen V-Forces on my 780 triple project. The stock carb boots have those air-guides on the sides, i had to cut them off and taper the intake in order to mount them to the V-Forces. I havent run the engine yet, Im prepping it to install in my 02 MXZ. But after cutting the side air-guides, (or whatever they are called) the fit up was just fine. I also had to trim my intake gaskets to work with the bigger V-Force cage. However, all that said, I would give Boyesen a call and check with them to be sure. Hers a link to their site http://www.boyesen.com/
Phone number: (610) 756-6818
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
Yea I called boysen and couldn't get a straight answer about what could happen just that they don't recomend it so I don't know what to think thanks for the help!!!
My guess is the reed cage failed 1st resulting in a smoked reed. I'd check with V-Force 1st to see if they may help out. There have been issues with the first run V-3 set-ups.
"You should never smoke in pajamas..
You might start a fire and burn your face..
Maybe you should return to Manaugua..
You could go un-noticed in such a place"
FZ
Ass,gas or grass....nobody rides for free!
Ride free,Brotha. See you in Heaven.
You are correct sir the cage Did fail first thank god that all of those broken reed supports didn't hurt the piston called v force and they said send them broken cage and they will replace it that made me feel better about this whole situation. Rage cages came in new boots came in put it together tomorrow . Now I will be able to tell every one which is better v force or boysen I didn't run the boysen's yet but I am already impressed with the fit and finish. I will keep you posted how they perform![]()
Cool. I have heard from many people that Moto Tassinari (V-Force) really stands behind their stuff...
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
What is this guy talking about ? I don't think he know's!!!!![]()
That would be athat should be
Has another comepletely irrelevant post in the thread about racing a modded 250r vs a modded Can-Am renegade...
Just looked at the rest of the posts made by this clown and reported him for spamming....Cant abide BS spammers....
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
