If the spark plug is out, it should turn over like cake.
I'd take the clutch cover off and the clutch; Then check the main shaft, counter shaft and then pull the flywheel cover and see how it turns over.
Sounds like something is binding, maybe a thust washer in the wrong place? or a top end issue.
I'd check each item as I tore it down to narrow down whether it's in the center cases, the outside (kick/clutch side) or the top end.
I've seen binding simply in that external kickstart assembly, the guy didn't use a gasket and it was tight when kicking over.
From your description, it sounds like something is wrong.
