Just set it by hand bring the crank to TDC with the spark plug out and the drink straw in the spark plug hole to find TDC. Then move the cam until the gear lines up with the mark on the rocker cover. Take the timing adjuster out and push the rod under it down put the timing chain back on make sure every thing is in the right spot and every thing was been torqued to honda specs, put the adjuster bolt back in. I dont not remeber how to adjuster it off hand but, I believe its take the little bolt out that is one top of the adjuster fire the bike up let it run at 1400RPM then put the bolt back in. I may be wrong with that.
1984 110 project
1984 125 parts bike
1983 honda 200x
19 85x2honda 200x
1985 honda 250sx
1985 honda 250es
