Results 1 to 15 of 15
Thread: carb question
    Dec 2007
    WI
    43
    carb question
    hello
    I think my carb is not working right when i crank the engine over and check the plug the plug is not wet. i had cleaned the carb VERY well i uses a compresser and blow air thru the passgaes,jets,etc... my engine now has 150 psi compression and when turning it over i can feel the "sucking" when i put my hand over the carb. my question is what iam missing in the carb that is not making the gas go thru... i know my plug should be nice and wet right?
    thanks
    79fordblake's Avatar
    79fordblake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    Wingo, Ky
    278
    No, the plug should not be wet, that means it is flooding out. Make sure there is plenty of fuel in tank, fuel valve is on, good fuel line and good clean filter.
    1981 Honda 185s
    DG Exhaust, Clamp on Uni Air Filter
    '85 200x carb, 200 Cylinder (SOLD)
    1981 Honda 185s
    Straight Pipe, Uni Air Filter
    200x Carb, 200 cylinder (SOLD)
    1985 Honda 250ES Big Red
    Uni Air Filter
    1986 Honda 250ES Big Red
    Uni Air Filter
    Dec 2007
    WI
    43
    ahhh ok well i cant tell if its getting gas to the plug? it dont seem wet and yes to your question about fuel valve etc
    Jan 2011
    Upper pennisula of Michigan
    55
    is there fuel in the float bowl?
    Quote Originally Posted by Cave Rider View Post
    POLARIS- IS AN ACRONYM FOR "People Often Learn About Reliability Issues Soon" or " Pull Over Loser A Race Is Starting" jkjkjk !!! no im not,or am i
    Dec 2007
    WI
    43
    last time i check yes there is
    Dec 2007
    WI
    43
    when i say i clean this carb i really clean it, took it all apart clean everything! the plug should be alitte wet right?
    May 2009
    Wingo, Ky
    278
    Gas should be getting to the plug unless the float and needle is stuck in the up position in which case gas will not go into the carb.
    1981 Honda 185s
    1981 Honda 185s
    Uni Air Filter
    Uni Air Filter
    Dec 2007
    WI
    43
    when i blow air thru the passages i could feel the air coming out thru the holes in the carb body if that make sense
    Dec 2007
    WI
    43
    maybe the plug is alitte wet and i cant see it? its a brand new plug
    Dec 2007
    WI
    43
    ok i there is a bass tube at the front of the carb if i put my hand over the carb and crank on the engine gas then i get some gas
    May 2009
    Wingo, Ky
    278
    You should be able to blow air through the inlet of the carb when the float is in the down position and shouldn't be able to blow air through the inlet of the carb when the float is in the up position.
    If the carb is getting gas the engine should flood after a few pulls with the choke on unless it starts.
    1981 Honda 185s
    1981 Honda 185s
    Uni Air Filter
    Uni Air Filter
    Dec 2007
    WI
    43
    hummmm ya and if it floods of coruse plug would be very wet hummmmm in which case its not very wet when the choke is on hummmmmm
    Dec 2007
    WI
    43
    i have the engine on the bench with the gas tank and yes gas tank is above the engine! But i have the throttle valve off ( top of carb) that is still on the atv would that make a differnce? i know that has the high needle in it
    Aug 2004
    Ab Canada
    4,368
    What is this on??? and yes you need that Slide and cap in the carb To pull the fuel through.
    1985 Tri-Z-
    Dec 2007
    WI
    43
    its 1985 125M ahhhhh on the slide ok well that explains it damm it i wanted to test this on the bench to make sure its pulling fuel thr before i install the motor
