OK So my klt is really slow and geared so low that i cant get any speed out of it. I know this trike isnot ment for speed but does anyone know if theres a smaller rear sprocket that will fit on this thing? the bolt holes on my spare sprocket are: 103.65mm (3.937inches) from center to center across the center (its 4 bolt holes so opposite holes) and the center hole is: 70.02mm(2.256inches) large in diameter. If i can find one that the bolt holes are close i can probablly take it to school and mount it in a vertical mill with (cant remember what its called) and make the holes the right size.
