Results 1 to 7 of 7
Thread: 85-89 250R Engine Cases...
    May 2002
    Texas
    2,670
    What would cause the clutch side case to bust here? This is not my case but mine is repaired in the same fashion.
    Just curious?
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    mine is like that too!
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    My cover was off for weeks so I got a good look in there replacing the clutch and all.... - I believe if you drilled through that patch you would hit the bolt that holds the main gear onto the crank and another gear that drives the counterbalance gear. I guess the bolt came loose?? Hmm, cannot for the life of me think anything else??
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    I don't know either Jeb, but I've got a "spare" sidecover up in my junk that has a whole chunk knocked out of it from there all the way down to the bottom. Just a big peice gone.
    CartmanKXT250 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Traverse City, Michigan
    198
    Mine is like that as well - It's caused by the crank nut coming loose and colliding with the cover...very common problem on the Rs....anyway heres a picture of mine
    03' Silverado SS | 04' YFZ450 | 87' TRX250R
    www.silverlakesandduners.com
    ELake on the forums.
    May 2002
    Texas
    2,670
    Yep, MRATC pm'ed me and explained that the damage is caused by a bolt backing out and breaking the case.
    Carty, Nice R man! You've come quite a ways since the days of the "pink bastid" ! :-D
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    Nov 2002
    198
    lol thanks...I ended up selling the pink/green monster to a friend of mine....the ATC is scary fast. It's got a +10 swingarm and it still pulls it up with no problems..that photo was taken at LS in Oklahoma, I borrowed an aluminum rear axle from a friend, the only tires we had for a banshee bolt pattern were 22x12x8 10 paddle ultra lights...a little too much tire for a stock cylinder but they worked pretty good..I'm planning on going down to Silver Lake next weekend, I put my 21x12x8 8 paddles on it and launching in 2nd gear is no problem at all. I've got a 55 gallon drum of methanol to burn up so it should be an intresting weekend! haha
