Thread: jetting help
    Nov 2010
    jetting help
    I have a 84 200x, that is getting rebuilt. I have a 12-1 wiseco piston, unifilter and an aftermarket exhaust. Where should i start with jets? I beleive it should be a 110 in it right now.
    For those mods should start with the next jet up or what?
    steve
    84 atc200x
    84 atc125m
    66 s90
    78 CB750F SS
    Nov 2010
    back to page one for someones insight
    84 atc200x
    84 atc125m
    66 s90
    78 CB750F SS
    camoweasel's Avatar
    camoweasel is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Pennsylvania
    180
    Start there. Compression changes should not effect jetting.
    Nov 2010
    Its still jetted stock and im putting the exhaust and filter on at the same time as the rebuild
    84 atc200x
    84 atc125m
    66 s90
    78 CB750F SS
    Jerm1179's Avatar
    Jerm1179 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    Clevelandish, Ohio
    387
    go up one size and start there....prolly have to adjust the needle clip too...youll just have to play with it to get it right...every motor runs a little bit different...this place sells cheap jets http://www.jetsrus.com/ good luck
