Results 1 to 15 of 17
Thread: Ebay 350x bolt kit ?
    House Springs MO
    5,496
    Has anyone use one of the ebay bolt kits for the 350x. I really don't want to go through the hassle of cleaning every bolt and nut on my bike when it goes back together. My only concern is that they aren't the same head design and might look funny.
    Just looking for some input from those that might have used them.
    jrsqlc's Avatar
    jrsqlc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Northwest O HI O
    321
    i was wondering the same thing... i wanted the stainless kit
    fire1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    Roanoke,Virginia
    404
    ive used the stainless 350x bolt kit and it worked fine only thing is there polished allen head bolts that might fit you theme.On my last build FlyingW over at org has oem bolts he had zinc plated and put together a 350x kit .So that way you have new looking oem bolts .Or if you have a plater in your area you might check to see what they charge its normally by the pound
    Oct 2006
    Titusville, FL.
    631
    I was also thinking about buying this bolt kit, but just a little unsure!
    861
    I'm using the ones for my 250R that the fastnerguy sells on ebay. There is a couple things I emailed him on and waiting for a response yet from saturday. They do look nice.
    ]1986 ATC 330R
    House Springs MO
    5,496
    Quote Originally Posted by fire1 View Post
    Do you know if he still offers the oem bolt kit? Are the allen head bolts in the ebay kit for the engine? Because I think that would look good with allen head fasteners for the side cases and engine dress.
    ametzker's Avatar
    ametzker is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oregon
    170
    I am ordering the kit for the 200, but i'm using it on the 185s. I know some won't fit but thats the only kit I can find. Besides for $30. No biggie
    Jul 2008
    Roanoke,Virginia
    404
    as far as i know he does . the bolt kit i used from fastnerguy was for the entire bike i think the only thing you do not get is foot peg bolts
    oregon
    668
    This is my trike.
    There are many like it, but this one is mine.
    My trike is my best friend.
    It is my life. I must master it, as I must master my life.
    Without me my trike is useless.
    Without my trike, I am useless.
    I must roost faster than my enemy who is trying to beat me to the finish.
    I must beat him before he beats me.
    Before God I swear this creed.
    My trike and myself are defenders of track.
    We are the masters of keeping quads the losers.
    So be it ... until there is no quad left.
    May 2008
    Northwestern Ontario, Canada
    552
    I got the kit for the 250r and it was great, no issues and everything worked fine.
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    Apr 2008
    somerset ma
    1,822
    My X has a kit from the fastnerguy. It's well worth the money. there are some bolts that it doesn't come with though.. The footpeg bolts, swing arm pivot bolt, and a few others. But other than that, it comes with everything. And it's pretty sweet to look at when it's all done..
    Tank
    House Springs MO
    5,496
    I ordered mine today. I just got through with tearing my bike completely down and between the broken bolts and the really rusted ones, it was pretty much a no-brainer to get the kit.
    861
    I read on the other board they come loose and to use loctite. I myself was unsure weather to never seize or loctite.
    ]1986 ATC 330R
    ^ I've never had a bolt come loose.....
    I used Fastner guys kit also - do not use the suspension bolts, they are 10MM x 1.50, instead of the OEM 1.25 pitch; Which is the same issue with the footpeg bolts. He ought to just leave them out. Reportedly the suspension bolts are not strong enough for other suspension applications (like a bolt furnished with a nut)
    Make sure ever fastner is long enough or not too long. He is buying 6MM x 1.0 x 5mm,10mm,15mm,20mm,25mm and if you call for a 22 or 27mm you may have an issue. Every bolt should be checked for the standard rule. 8mm bolt has to use at least 12mm of thread length holding. Diameter x 1.5 is the rule..........
    Also, I'm sure Tank meant to say that it does not come with a swinger bolt, OEM only.
    House Springs MO
    5,496
    Thanks for the heads up Dirtcrasher.
