Thread: 185s Choke question
    Jan 2011
    kingston ontario
    5
    185s Choke question
    I have an 83 185s that i got in pieces. I was wondering if anyone can take a picture of the choke lever. mine seems to have extra parts, wondering if it is even for this machine (see pics). My choke stays engaged unless i hold it down, I must be missing a spring of sorts? whats the braket with the cable for? any info or pics would be greatly appreciated.
ID:	118022Click image for larger version.
ID:	118023Click image for larger version.
    1984 honda 200s's Avatar
    1984 honda 200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    Calumet Island, Quebec
    446
    yours has a cable that attaches to it with a pull knob.
    ktmbk's Avatar
    ktmbk is offline At The Back Of The Pack Arm chair racerFirst time rider
    Long Island
    154
    I agree, yours does have a cable setup, not like mine which does not have that bracket. It should be the other way around as far as engagement, the choke is on in it's rest position. For reference each position (3 in all) should hold it's position without slipping into another.
    Looking at your picts, and if I remember correct, your choke looks ok. That lever is what holds the butterfly open, the spring in the choke holds the butterfly closed in a rest position, and there should be a plate with three holes in it to lock the carb into it's positions.
    PM me if you need picts, I am in the middle of building a 81 carb for a buddy (which just has different jetting), I can take picts as I go for you.
    Jan 2011
    kingston ontario
    5
    Thanks for the input guys. Is this choke option on teh 185s? I have not seen anything in the manual regarding the cable choke. Anybody have any info on those ebay carbs? do they come with the choke assembaly?
