Looking for a picture of where the header pipe bolts up to the engine on a 250 big red. Trying to figure out what mine is supposed to look like, one of the bolts seems cut off.. not 100% sure though. If anyone can help, thanks!
Here is what mine used to look like. It's fixed now.
Here is a much better pic from one on ebay
Thanks for helping so far. I'm going to take a better look at mine and take a few pics. Maybe you guys can help me decide what I should do.
If you need new studs, I can take care of it. I have a fairly well equipped machine shop; Read my sig below........
I can replace both of them with stainless steel if you wish.
If you break a drill off in it or break a tap it gets much more expensive![]()
Just checked my set up. I got one stud out ok. The bottom stud is broken, showing about a half inch of stud sticking out still. It's locked in there pretty good though. I might try welding a nut on it and pulling it out with a little heat.
