Results 1 to 9 of 9
Thread: at a loss on air cooled 250r
    Feb 2008
    Texas City, Tx
    27
    I have a 82 250r that runs away everytime it is started. I can't seem to Finda vacuum leak I have replaced the intake boot and intake gaskets but still doing it.when it taksoff I can pull the spark plug boot and it will keep running.the only way to kill it is plug off the intake or it run out of fuel.please help!!
    82 Honda 250r
    84 Kawasaki tecate 250 SOLD
    84 Honda 200es Big Red SOLD
    85 Honda ATC 250es big red
    85 Honda fl350r odyssey with a 400 big bore kit. SOLD
    85 Honda 250 fourtrax
    01 Yamaha yz125 with 140bbk & other mods
    07 Honda 500fm fourman with IRS, 515bbk, 30%gear redution and 29.5 outlaws and other mods
    Crest California
    3,014
    Is the slide inside the carb installed wrong? Make sure it can close all the way an open all the way when you put it in.
    LED obsessed
    2015 Yamaha FJ-09
    ontario
    1,131
    Ok I dont want to sound like an idiot, but what kindy of gas do you have in it? I have seen lawn boy lawn mowers (2-strokes) do this and it turned out that some one had put diesel into there fule, it had all the same simpson as you are saying your 250r has???
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Windham, Ohio
    147
    X2 on what express said.My 81 did the same thing when I started it for the first time.Look down the bore that the slide goes in, there should be a little tang opposite the idle adjust screw and make sure that it goes into the slot on the slider that runs the entire length of the slider.
    Feb 2008
    Texas City, Tx
    27
    slide is in right im running premium grade gas with honda 2 stroke oil
    82 Honda 250r
    Nov 2006
    southern oregon
    2,338
    i've seen misadjusted throttle cables do this after a rebuild. Or sometimes the cable housing can slip out and get caught on the carb cap. Throttle should always have some free play. You should do a leak down test to check for airleaks. Are you using the correct spark plug?
    2-stroke lover
    Feb 2008
    Texas City, Tx
    27
    when this first started i rode it one weekend and it sat through the week in my garage and the next weekend i started it up and it took off. i have since tried all i can think of i have rebuilt the carb, replaced the reeds, reed cage gaskets, replaced the sprk plug, i just ordered new top end gasket kit to replace the jug and head gasket... i dont know what else to do.
    82 Honda 250r
    plymouth,il
    1,231
    Do a leak down test I was having a similar problem on my 83 250r I though it was a leak turned out my dad had turned the idle adjustment screw all the way in for the highest idle possible it sounded like it was gonna blow.
    Heres a link to build your own leak down tester for about 20.00
    http://www.3wheelerworld.com/showthr...r-for-about-20
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
    Feb 2008
    Texas City, Tx
    27
    ok off to lowes i go.....
    82 Honda 250r
