Results 1 to 13 of 13
Thread: Another Diagnostic Quiz
    Rittman, Ohio
    6,276
    This should be an easy one. I drained the fluids from my TriZ, and this is what I got.
    1. Identify what is in each container.
    2. Expain why each looks as it does.
    3. Explain the possible cause/causes of this phenominon.[/img]
    May 2002
    Texas
    2,670
    Round container: Crank Case Oil
    Trapezoidal Container: Coolant.
    Problem Looks like water in the oil and oil in the water. :-D
    Cause: Bad Tri-Z water pump seal.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Detroit, MI
    837
    Without looking at anyone else's reply, I guesstimate that it is coolant in the red container with oil in it form possibly a blown base/head gasket? I guesstimate that the black container is the tranny fluid with A LOT of water in it. What from I do not know. Could be old, could have left the crankcase fill plug open and sitting outside, could be from fording(???) a body of water, and it got into the cases without being drained out immediatley afterwards. If it were a car could tell you more accuratley what it is from, and I've never worked on a water cooled 2 stroke before.
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Re: Another Diagnostic Quiz
    Quote Originally Posted by TimSr
    Left: Was oil.
    Right: Was water mixed with antifreeze.
    Cause For the Left: crank case breather hose went under, Someone delibertly mixed water into the oil (Hey, that would cause that ;-)), bad water pump seal.
    Cause for the Right: Bad water pump seal which are notorious for going out, or someone delibertly mixed oil into the coolant :P.
    350Xrider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2002
    Huntington, W.V.
    320
    I'll agree with the both of you on this that it is the water pump seal. I would say the motor was swamped, but since there is oil in the antifreeze I'll have to go with the seal.
    ATC350X,ATC70,1991 RM 250,XR500,TM400,TS400,Foreman400 4X4,Polaris 425 Magnum,ATC 90, 1982 175,1973 Honda Trail 90,1980 CR80,1981 CR80,
    Howdy's Avatar
    Celina, Ohio
    10,079
    My guess is the carb wasn't jetted properly and caused the fibulator valve to open thus dumping antifreeze in the oil and vice versa.
    That one was for you TiM Sr. lmao j/k
    Tri-Z_Jim is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    w/o looking at previous posts
    water pump seal. Anyways,,,,since the oil and antifreeze mix so well and keep everything lubricated and cooled off.Why bother changing the seal lol I've only had to change the blue Z's so far.I changed it in my old KX250 about 6 times in 6 yrs.
    Jan 2002
    Huntington, W.V.
    320
    I put one in my old YZ 80 I used to have and my KX could use one now.
    Washingtons Crossing, Pa.
    2,977
    Mess
    Water contaminated, transmission mixed oil - Oil contaminated, non mixed anti-freeze - Now I agree with Howdy except that I think the cause is deffinately rear grab-bar related.
    Fresno Ca
    2,695
    looks just like my 87 cr80 looked the one on the right is coolant and the one on the right is tranny fluid
    waterpump seal went out
    Rittman, Ohio
    6,276
    I guess this was an easy one! I should just take the seal out, and run 50:50 antifreeze and oil in the whole works! I will say though, that having gone through this several times over the years, this is the first time I got oil in the cooling system. The crank oil contamination was all from the cooling system. I wasnt under water on that trip. This all occurred during the Haspin trip. It also seized while breaking it in on the track in all that mud, after losing the coolant. It unseized when it cooled back down, and I rode it through the weekend, but one ring was stuck, and the bore is goofed up. I now have it all torn down. Got the cases split, and have to replace a shifting fork which was causing first gear to slip, and a couple sets of needle bearings and crank bearings while the cases are split. Ill also be doing a bore job, and swingarm bearings. I guess its all overdue. I should have done all this before that trip, but I really wanted to go, and my R was down at the time. Should be like new in a few months.
    New Hampshire
    794
    You are all in error. The problem lies in the muffler bearing seal. Replace the seal (and bearing for good measure) and you will be in good shape.
    Apr 2002
    s.w. michigan
    6,498
    post
    timsr.
    due to you i checked my oil today in big red and found it was all milky looking. (totally submerged motor at badlands 2 weekends ago).
    just a shame that oil + filter only had 5 hrs. run time on it.
    would have never entered in my mind to look at it had it not been for your post.
    probbly won't run it any till next spring + thought you outta know.
    john (jeswinehart@hotmail.com)
    p.s.- i have another tape for tim jr. to wear out.
    e-mail me your mailing address if you would please.
