Thread: Building a 86' Tri-Z 250
    Northern CA
    1,104
    First time to this site and what a great one!!!! I am going to build this from the frame up. All I have so far is a frame and was wanting to know if anyone knows if 85' parts will fit the 86'. Plastics, radiators, swingarms etc. I need everything. I have an 86' already completly stock and fast. I want the new one to blow everything else off the dunes. Any info you might have would be wonderful. Trikes forever!!!!
    Thanks in advance!!!!
    85' Tri-Z 250
    85' Drag Tri-Z, BBBBBRRRRRAAAAAPPPP!!!
    85' 350X
    06 TRX90
    78' ATC70 Project
    03'250EX
    87 Ninja750 3wheeler
    May 2002
    Texas
    2,670
    Welcome! I think the 86 & 85 frames are a little different. Coolant reservoirs are different. rear rims are different but will interchange. front forks on the 86 are bigger than 85, so make sure you get the right triple clamp. 85 has a 5 speed tranny, 86 has 6 speed.
    Good Luck! Let's see a pic of your 86 Z.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    hey i have alot of 85 Z parts.. PM me with what all you need
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    As far as I know the only difference between 85 and 86 was the 86 had bigger forks. 86 has a 23 inch tire instead of 25 inch (I run a 23 inch on mine an its a whole lot better than the 25) I think that carb settings were different between the years, but as far as radiators, swingarm, plastics, it will all work the same on both models. Oh yeah, almost forgot 86 has 6 speed while 85 has 5 speed, although I have heard that the 6 speed gears will fit in the 85 cases and vice versa.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
