Results 16 to 30 of 48
Thread: Im finally ready to machine you new parts.
    Mar 2008
    EastGreenbush, newyork
    3,494
    very cool swigin!! i have loosely followed your lathe resto thread(good stuff)!! Glad to see your gonna get right down to putting that beast to good use. If i need anything, i will hit you up.
    Typical Applications
    303 is used almost exclusively for parts requiring machining, grinding, or polishing where good corrosion resistance is also required. It’s non-seizing and non-galling properties make it ideal for moving parts. Being an austenitic steel, it is useful where low magnetic permeability is desired. 303 has fairly good forming properties. Used for aircraft parts, as well as shafts, gears, valves, valve trims, all types of screw machine products, bolts, screws, and machine parts, as well as architectural purposes. It is not recommended for vessels containing liquids or gases under high pressure.
    PA
    3,515
    Thanks for that DC!
    Funny thing is thats what I thought I'd use if I go that way...lol
    thanks for making up my mind for me.
    WWW.HREATV.COM
    PA
    3,515
    OK guys, I just ordered a bag of nuts and some tool steel, don't leave me hanging...lol
    WWW.HREATV.COM
    zzmegad's Avatar
    zzmegad is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2008
    North of Chicago
    317
    17-4 PH SS is strong with great corrosion resistance. Of coarse its expensive and not as easy on tooling...
    Quote Originally Posted by SWIGIN View Post
    Thanks for that DC!
    Your welcome, your always correcting or adding to things I post............
    I just know that when you say "Stainless Steel", guys like that!; Who doesn't want a shiney stainless bolt??
    It's strong,tough and takes quite some time to turn down lathe-wise, then "THREAD IT!!"
    glendive, montana
    1,822
    If I was to use any stainless on a trike part I would use 416, just for the simple fact it wears out less and is easier to machine, than 304 or 316 which is gummier, granted it is easier to corrode, but when it comes down to tensile strength vs. corrosion I would choose tensile strength any day, I agree with your choice on avoiding stainless. for the price of stainless I would rather have something that I know my fat butt can hit that jump and not break the bolt when landing or bend it, I machine 316 and 416 all the time, and in my opinion 416 is a way better material for shaft work, also comes out with a better finish when completed. One thing to remember with stainless is to rough it in with coolant, and let it get cold again before finishing it off, the heat expansion can get over .016 in the end which will scrap a part in the end other than 304 I have not had the luxury of dealing with any of the other stainless out there, but I can tell you this of you are able to bend or break tool steel or chromally you shouldn't be on that trike as it is being rode way too hard
    Mar 2007
    Texas
    5,045
    how much for 200x bolt? I'll work a deal out with you. I have a NEW in the plastic oem honda 1st gen 200x swingarm bolt. if you make me a tool steel one i'll let you use it for reference. reemmeber this is new in the bag. not rusted.
    ________________
    https://www.mikesatvfix.com
    PA
    3,515
    Man, I keep forgetting about all the weird swing arm bolts. I can make one but I did not order any steel near large enough for the big end. Could you get me a quick diameter of the big end and I'll order some in. I will definetly need yours to look at, I havn't owned a 200x since around 1990.
    Like I said earlier, till the end of the month, simple swinger bolts and front axles will be $35. More complex or stepped bolts/axles are $40.
    WWW.HREATV.COM
    Mar 2007
    Texas
    5,045
    if you want, we can do a 2-for 1 trade. you can HAVE my new bolt in exchange for 2 machined ones. deal?
    yea let me get you the demsions.
    ________________
    PA
    3,515
    No thanks, I know where I can get my hands on a 200x bolt to measure.
    WWW.HREATV.COM
    Apr 2008
    Kalamazoo, Michigan
    814
    I've got one for you, I want to get a longer swinger bolt for my 350x because of the gusset kit. Not sure how much longer... Maybe DC can chime in and tell me how much longer.
    Leave feedback for me here : [Please Don't start another thread again!]
    http://www.3wheelerworld.com/showthr...for-MagicJames
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    ^ Just add the thickness of the washers. There usually about .060 or a total of .125 (1/8th) of an inch longer.
    I try to put thick washers on there. Do you have Bills kit? Just measure them up............
    Apr 2008
    Kalamazoo, Michigan
    814
    Yes i do, It's been sitting in my garage for ... ... ... 7 months or so, I'm trying to get my brother in law to weld them on for me so i can get rolling on my 350x project.
    That's a good idea, maybe a solid 3/16 would be safe, as i'm gonna try to beef up this frame so i don't break as much stuff as i did last year
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
  15. #30
    Stock bolt may work. You'll just have to see how far it threads on and if it catches the "self locking nut portion" or Loctite it in if the whole nut threads on.........
    You could stake the nut too if it fits.
