if a 250r engine is bored .060 over is that a bigger cubic centimeter size or is it just for putting in a new top end? like if its a 250 how much is it bored out to be a 300 or 330?
thanks
thanks
no more toysmaybe buy a 250r?
past:
86 250r
88 quadracer
83 200x
really, no one knows???
past:
86 250r
88 quadracer
83 200x
.060" over is only 1.5mm over standard bore. It's for rebuild purposes. (.060 will get you from 246 to 254 is cc)
Edit: A 73mm bore will give 301cc. That's more than .275" over. (7mm)
I found a displacement calculator somewhere, don't remember where???? but just rebuilt top end on my R, 1.50mm over making the bore 67.5mm, displacement turned out to be 258cc.
'74 ATC70 (stock for my nieces)
'84 ATC70 big carb, race cam, and piped (big boys little toy)
'84 ATC125M
'85 ATC125M
'85 ATC185S (200X carb and pipe)
'83 ATC200X (my first trike ever, avatar pic)
'85 ATC200x
'85.5 Tri-Z 250
'85 ATC250R
'79 CJ7 w/351 Cleveland
'77 XL75, '78 XL125
'88 Katana 1100
'00 King quad
'05 LTZ400
Bore X Bore X Stroke X .7854 = cc size , you have to move the decimal point to the left one point on the bore and stroke .
I got a PSI performace flat track ported cylinder and its 50 over now and it need a bore is there cooling issues with it being bored that far?
]1986 ATC 330R
