Thread: Quick ?
    Tucson
    1,652
    Quick ?
    Is the 86 trx250r swing arm the same as the 85 86 Atc 250r swing arm??
    Tucson
    1,652
    Guess nobody knows!!
    Tecate Karl is offline Check my feedback before buying from me First time rider
    Virginia Beach, Virginia, United States
    163
    yes I checked the service manual it changed in 88
    Tucson
    1,652
    Thanks karl!
    House Springs MO
    5,494
    '85 swing arm is the same lenght as the '86 but it uses a different bearing carrier, axle, brake caliper bracket, and brake stay. So if your putting a '86 TRX swing arm on an '85 you have to use all of the '86 stuff. If its going on an '86 then it will all interchange.
    Tucson
    1,652
    Thanks bkm, good info!!
