Results 1 to 15 of 28
Thread: Umm, changed my oil an found a chip. HELP
    Aug 2010
    Southern Oregon Coast
    932
    Ok, so I just drained the oil in my 85 250r and out came a small chip. here's pictures: (penny for reference)
    The oil was pretty metallic looking but I used most of a quart of cheap oil and flushed it out. Its aluminum. It shifts through all the gears with no problem.
    Any ideas?
    Wichita, Kansas
    1,361
    God, thats always scary to find. You can flush the bottom ends with diesel fuel. run for about 30 seconds, then remove all fuel. Replace the diesel with oil, run for a little while, then change very soon, within 10 minutes. After that, run what ever oil you normaly do.
    If it was my trike, i would take the clutch cover off and take a look around.
    After thinking about it, i still can't figureout what that chuck came off of. I say take the clutch cover off, it may be visable and easy to fix. What ever broke.. will probably just continue to fall apart over time and destroy the rest of the tranny.
    6,810
    Check it with a magnet . If alum (piece of the case) you might be ok but if its a steel part it might be something important .
    Jan 2011
    Brazil, Indiana
    2,087
    It looks to me from what I can see in the pictures to have fresh breaks on both sides. So more than likely there is another piece in there. Id tear it apart. Its not worth risking junking a motor that is getting harder to find every day by not taking any action.
    Last edited by hoosierlogger; 03-06-2011 at 09:43 AM. Reason: post sounded wrong. had to fix it.
    Dec 2009
    BFE
    1,202
    My buddy changed the oil in his 200 big red and a small spring like whats in a ink pen fell out! Still runs and shifts fine... for now.
    "I'm Kind Of Like The Turtle Man Of 3Wheelers."
    1986 Honda 350X
    1985 Honda 250R
    1985 Honda 200X
    Apr 2003
    HARTFORD CT, USA
    478
    I agree pull the sidecover , clutch side its worth the time for sure.
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
    Sarnia, Ontario, Canada
    3,415
    Looks like a big piece of 'ah Shlt' to me..!!! I'm with the other guys..tear it down before whatever that came off of blows to hell..
    Might be tooth from kickstarter..just a rough guess
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Aug 2010
    932
    First off, thanks to everyone who offered advise. I pulled the clutch cover off and pulled the clutch basket and didn't see any damage. I pulled the motor out of the frame tonight and will work on splitting the cases in the next couple days...
    Jan 2011
    Brazil, Indiana
    2,087
    good luck, I hope its dont cost you an arm and a leg to fix it.
    Aug 2010
    932
    Thanks hoosierlogger.
    Does anyone know if the stator has to come off to split the cases? I got the 3 bolts off that go around the edge of the stator that you can get to with the flywheel on (not the ones that hold the stator on), plus the two long ones for the counter-balancer and all the bolts on the outside.
    osoyoos bc canada
    1,057
    the flywheel has to come of to split the case and if you do you will need new berrings they dont like being pulled out and put back in
    Gear tooth or part of a shift fork - my guess.......
    Good luck!
    Mar 2007
    Texas
    5,045
    yea looks like something important.
    keep us posted and take lots of photos.
    ________________
    https://www.mikesatvfix.com
    Aug 2010
    932
    Ok, so I feel good that I split the case and found NO SIGNS OF DAMAGE but its also gets me that I went through all that for nothing. I guess the chip was from the land of magically appearing mystery chips.
    here's the pics, the camera light does funny thing and makes it looks all dirty but it is clean. But whats up with the blue over spray??
    gaskets will hopefully be here Saturday...
    glendive, montana
    1,822
    I't kinda looks like the chip might have come from the area right of the blue overspray, but that could be the flash and silicone mix, also have you checked the bottom of the piston, I am assuming you have but check the inside of the bottom of it as well, that chip came from somewhere, maybe it has been in there a long time, and maybe not best to check every where
