Results 1 to 7 of 7
Thread: checking oil?
    Watertown, New York 13601
    3,382
    checking oil?
    how do you check the engine oil in a tri z 250? I took the cap of but there is no dip stick. and what kind of oil and how much.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    On that crankcase there should be a screw (should say"oil check") where you can losen it. When filling it,having that screw lose oil will be coming out,when it does it means that is the full level. Make sure you retighten the screw. I think i explained good? if not someone will correct me. :?
    As for how much,i'm not sure.
    Ashland City, TN
    2,576
    Nope you said it good. the screw is to the right and lower than the oil plug. you'll see it.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    3,382
    so fill it to the top? what kind of oil?
    2006 YFZ 450
    Ashland City, TN
    2,576
    NO DONT FILL IT TO THE TOP! Take the screw out on the right side cover, then start putting oil in. When oil starts to come out the screw hole, you've got enough oil. I run the QuakerState 10W40 for me, works fine. After I rebuild I think I'm gonna switch to quaker syntech and see how it works. I'll get a pic of the cover sometime.
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Michigan
    2,718
    If you fill it to the top,there will be some problems. Just make SURE that screw on the side of the crankcase is lose.
    May 2002
    Cortland, NY
    1,195
    I always ran amsoil crank case oil in my Z.
    http://photos.yahoo.com/dynofox250 (TF 03 pic's)
    Trikes: Restored '86 ATC 250r, original and mint '83 185s
    Quad: '86 TRX 250r
    Sled: Rev X 800ho mod
    Bike: '00 ZRX 1100
    TF '03 and '05 Survivor
