Results 1 to 15 of 21
Thread: 200x exhaust.....?
    jsmay's Avatar
    jsmay is offline Just Too Addicted Arm chair racerJust too addicted
    Jan 2005
    Hendersonville TN
    593
    200x exhaust.....?
    ok... who is still making exhaust systems for 200x's... is dg and cobra the only choice? will an exhaust for a trx??? fit on a 200x? just wondering....? thanks guys.
    Pacific NW
    4,255
    I have a cobra that needs repacking frequently and is only comfortable with ear plugs for me.
    The other 10+ trikes haul &*(%$ and are quiet.
    If it's an issue for you, make sure it meets off road db ratings AND spark arrest
    requirements or the cops can impound your mo cheen.
    Other folks on here know tons more than I do about freeer flowing, rejetting etc tec so surely someone will chime in soon.
    jsmay's Avatar
    Jan 2005
    Hendersonville TN
    593
    thanks for the heads up on the cobra... not looking for loud just something better than what i hae now....an old stock thats pretty much a hollow can.
    Pacific NW
    4,255
    If you can keep your eyes open, a whole parts trike may come along for the price of a new exhaust.
    I like stock and the famous honda 1 kick start, puuuurrrrfect idle etc,
    A tricky fancy new exhaust may cause you to take the carb off a few times to rejet because of the difference in air flow.
    I guess if a couple seconds over a 1oo yard run means that much to some people but I just wanna ride and not get tickets or start fires and quieter is better for me. Doesn't scare the wildlife.
    There's a ford tractor muffler people say will fit for like 25 bucks. Maybe fo4#
    Gander mtn had some multi hundred dollar silencer for 50 bucks.
    A good stock setup or similar is pleasing to hear idle and run.
    Our local outdoor power equip place has some pretty cool mufflers cheap too.
    Maybe they'd even give you an old one for free.
    Start penetrating oiling your mounting bolts and head studs once a day, but hopefully you won't have to go anywhere near the head.
    Maybe there's something that will simply slide inside your empty can.
    As a matter of fact, the x I traded for a br had a generic silencer jammed right into the rear can and it fit like a glove.
    It was about a foot long, same diameter exhaust pipe like 1 or 2 inch whatever it is, and the outer casing was a perfect fit with the stock can like 3 or 4" diameter.
    Feb 2009
    michigan
    2,387
    i use a dg.mine works great and aint loud.it is louder than stock though.
    1985 ATC 250R
    . Team Red Trike
    Find a Supertrapp for a 350X and have a mid pipe made up.
    I nabbed a nice one last week for 75$, no one bid...........
    matt86200x's Avatar
    matt86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Canada Eh!
    366
    Can you tell me more about the ford tractor muffler. Part# does it need to be welded to the headpipe?
    85 250sx
    86 300es in the making
    86 200x
    86 350x
    Oct 2009
    lindenwold new jersey
    890
    check out Daltons200X 450 swap.... not much fabing at all if I remember and it sounded good. I just gave Robby a Kerker for Onnie's X. It's almost Harley sounding... I have the Supertrapp on my 500X. It's old school and needs a repacking
    LIVE IN EAST PA. OR NEW JERSEY THEN CHECK THIS OUT www.njdirtriders.com SUPPORT LOCAL RIDING WITH US
    Lauderdale County, Alabama
    2,029
    ****IN MY OPINION****
    Cobra's as a POS, DG's are nice, Bassani's are awesome, but SupperTrapp is one of my favorite pipes. But a good Bassani exhaust system is what I've found works best.
    Jerm1179's Avatar
    Jerm1179 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    Clevelandish, Ohio
    387
    i love my bassani...but its rather loud aswell..if thats a concern you might want to think about the supertrapp...if its too loud add a few discs
    Oct 2006
    Wapakoneta
    815
    Actually if the supertrapp is too loud you remove discs fyi.
    jsmay's Avatar
    Jan 2005
    Hendersonville TN
    593
    Do White bros still make pipes? I was hoping someone here may have tried a 250x pipe on a 200x... That may sound silly but if I had one I'd see if it was close... More options if it is... Cause they are the same as the 300ex. Or is there a universal fit muffler? Another question... I see dg offers a chrome system..does it hold up better? Looks like the head pipe is one piece over the plain steel 2 piece head pipe..
    Jerm1179's Avatar
    Apr 2010
    Clevelandish, Ohio
    387
    makes sense...opens it up a bit..ty
    Florida
    70
    If your old stock silencer isn't too rotted-out a real easy fix is to remove-it, and squirt a liberal amount of WD-40 down the exhaust port and leave-it soak for a few hours. Straighten-out & sharpen the end of a coat hanger, then poke at the baffles with a bit of force. Not enough to damage any weakend parts, but with enough force to clear the holes that get carboned-up. Carefully remove the cleaning-cap at the bottom / end of the silencer and shake-out the debris. Leave-it sit for another few hours to allow any remaining lubricant to dry-up before you reinstall. Sometimes it will smoke a bit from the residual lubricant burning-off, but it quickly goes away as most of any left in the pipe is blow out.
    My dealership mechanic told me this and I thought he was nuts.....but I tried anyway & I was shocked at the difference. My 250SX was a lot quieter & idled much better after I did it. I t always had a bit of a "hiccup" at idle prior to me doing this....and I never even noticed that it had gotten progressivley louder over the years.
    jsmay's Avatar
    Jan 2005
    Hendersonville TN
    593
    Quote Originally Posted by pjschulze30 View Post
    I would try that but there is nothing left to the inside... just the muffler shell... not rotted or anything just empty.
