Results 1 to 15 of 21
Thread: diesel engine oil for it's zinc and phosphorus content?
    Pacific NW
    4,255
    Some say it's better for steel to aluminum contact points
    like cam shafts to aluminum heads and has been generally decreased
    in newer motor oils for various reasons.
    Any suggestions?
    Any price shock on cases of oil these days (yet)?
    Time to bury a few case of something and it would be nice
    to get the right stuff that will work on a bunch of
    different machines.
    camoweasel's Avatar
    camoweasel is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Pennsylvania
    180
    I have used Rotella and Delo for many years. Both are hardy oils and loaded with zinc and phosphorus. Have you looked at the label on the new Rotella bottles? It is JASO MA approved.
    1985 Honda 350x - SOLD
    Wiesco Performance, Webcam grind #213, port work, White Bros E-Series, 400ex carb, open airbox, reinforced frame
    2009 Suzuki LTZ450 MX race quad
    Dec 2002
    deer park, texas
    2,336
    I have been using rotella for quite a while with no complaints. I think it was $13.99 a gallon last time i bought some.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    Nov 2009
    1,147
    I have used Rotella as well, awesome to see its JASO approved now. I have found Valvoline motorcycle oil (actually has slightly more zinc and phosporus and their ATV oil) for around $4-5 a quart. I should try to get the specs off Rotella. Valvoline has a PDF with specs of all their oils, zinc content, TBN, phosphorus, etc.
    Actually I just e-mail Shell to get the specs for Rotella so we can know how it compares to Valvoline wet-clutch oil.
    I've read it all over the net when you search "ZINC additive", lots of info about it and the havoc todays oils are causing............
    N.E. Ohio
    2,005
    My brother sells Oil, Grease, Specitality Lubes for Central Petroleum or CEN*PE*CO. He sponcers many of the ATPA truck and tactor pullers in the National Series. All their products are highly refined and exceed ALL others. Approved by JohnDeer MFG, as well as the top Military Grade Spec given by the US goverment. Nothing on the MARKET will meet their standards...Amsoil, Purple, GTX, QuakerState ALL take a back seat and have done so test after test. PM me for contact info. The Company has been around since 1911 as a small developer of FARM and Over the Road oils and lubes. All the products are conditionded for EXTREME use in both Diesel and Gas powered motors.
    Nov 2010
    Lucas makes a break-in additive that has added zinc to help with flat tappet cams and stuff.
    steve
    84 atc200x
    84 atc125m
    66 s90
    78 CB750F SS
    Nov 2010
    84 atc200x
    84 atc125m
    66 s90
    78 CB750F SS
    Oct 2007
    Minneapolis mn
    4,067
    Ripped this from the ZDDP website "After 70+ years of trouble-free, metal-metal engine protection, the E.P.A. is forcing ZDDP (Zinc Dialkyl Dithio Phosphate, containing both Zinc and Phosphorus) from domestic motor oil. If your engine was designed prior to the 1990s, your non-roller lifters require ZDDP in your motor oil to avoid premature deterioration."
    We use this stuff on all the old motors of the cars we build in the shop... (for what its worth)
    http://www.zddplus.com/
    Dec 2009
    the ville illinois
    477
    I use shell rotella in every engine I own. I also add some STP engine treatment, it has a high content of zinc
    Pacific NW
    4,255
    Quote Originally Posted by Thorpe View Post
    Nice, clean hit Thorpe.
    Very interesting read. Just a little shocked that I haven't heard about this topic.
    Then again, I quit building engines and transmissions professionally back in the 80's.
    But I also DO remember every Volvo that came in was guaranTEED to have a wasted cam.
    My tractor is a 47, car 82, trucks 89 and 92, trikes are all, well, 70-80's Hondas so I guess it's time to go look for some SDDP. But I want to get the right stuff.
    Most additives, especially particulate suspensions are almost immediately filtered out.
    Like the teflon slick50 types.
    I also liked the fact that there was little 'commercial bias' in the article.
    ametzker's Avatar
    ametzker is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oregon
    170
    Another vote for Rotella T. It was the oil I used at my shop. I wish I still had that 55 gallon drum of it left.
    RamsesRibb's Avatar
    RamsesRibb is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Louisiana
    316
    What a coincidence. Mickey Dunlap just recommended Rotella for all four strokes in another thread on this forum.
    Previously known as HighFlying101 since 2003
    I changed my email and lost my password
    Current: '85 Tri-Z , '83 250r , '86 Tecate, '80 ATC110
    Prior: '85 FTZ ATC350X, '85 Tri-Z, '85 ATC200X w/ Bassani exhaust, '83 Big Red, '81 ATC185S, '79 ATC110
    http://www.ipetitions.com/petition/tpctrikes/
    Feb 2008
    (southern) Wisconsin, USA
    974
    Good info. Thanks for sharing!
    Pacific NW
    4,255
    Now I just read that diesel oils are more 'detergent' maybe foam more
    and that diesel engines have less tight clearances so the oil really is designed differently
    than for gas engines.
    This is one of those times when the more I learn,
    the less I know.
