Results 1 to 8 of 8
Thread: 205r Pipe is loose. do i need a new exhaust flange?
    Leonardtown, MD
    594
    The pipe on one of my 1985 atc 250r is very loose. Loose enough that oil has gathered all around the area where the pipe enters the head and on top of the bottom end of the motor.
    What do I need to fix this problem? Do I need a new exhaust flange? Like this one?
    http://cgi.ebay.com/ebaymotors/Bille...-/200529225558
    or do I just need an exhaust flange gasket set like this one?
    http://cgi.ebay.com/ebaymotors/81-84...Q5fAccessories
    The silencer is not loose, it is secure. Its just the pipe where it enters the head. It does has the two springs that connect the pipe to the head.
    I figure that since this pipe is so loose it could cause an air leak and create a lean mixture, correct?
    Thanks for the help.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Miami,Fla.(305)
    808
    1st- is your pipe held at the mounting tab under the tank? The pipe shouldnt move around when fastenened down.
    2nd- youre gonna have to take it apart to inspect the flange fully. Does it leak before the flange (gasket) , or just where the pipe slips on (metal ring/seal)on the flange.
    You probably want to replace the gasket at minimum anyway. The metal ring/seal could be missing a piece or the whole thing.-Only one way to find out. Yes- a leak there is not good.
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Nov 2002
    Chezzetcook Nova Scotia
    1,836
    Go buy some high heat silicone. Remove pipe and clean off any oil. Smear some silicone around the whole pipe as well as the cylinder where the pipe goes in. Wipe ascess silicone off to make it look neat and tidy. And ill gurantee you will never have a leak again. Also works great for silencers.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Leonardtown, MD
    594
    Hmm that seems like a good idea.
    I will take the pipe off, inspect the flange and gaskets. If they look too far gone, i will replace them, if not, i will put some high heat silicone one it.
    edit*
    Wait, that might stop the slight leak, but it may not stop the wobble. I will have to give it a try and see if its not as loose.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    Nov 2002
    1,836
    Trust me. I can remove my pipe springs and mounting nut as well as the silencer bolt and the whole pipe assembly wont move. To remove the pipe takes alot of effort. Some people say its over kill but mine never leaks and dont have to wait for a stupid o ring to come.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    plymouth,il
    1,231
    My pipe on my 83 250r is leaking too what is this high heat silicone called I would like to get some.
    Life is better on 3 wheels
    1984 200es big red
    1976 suzuki rm125
    1983 honda 250r (minty fresh) SOLD
    1986 honda 350x (A PILE....for now)
    197? honda 90 (pauter framed little beast in the making)
    Leonardtown, MD
    594
    We should be able to find some at autozone, true value, advanced auto or even lowes.
    It should say on the packaging high heat silicone or something like that.
    I have seen it before at my local autozone. I havent had time to try it out yet though, been really busy with school.
    My Rides:
    1985 ATC 250r
    1989 Suzuki LT-160
    plymouth,il
    1,231
    I'll have to look I HATE when the oil drips on my nice clean frame and everything else.
    1984 200es big red
    1976 suzuki rm125
