Results 1 to 12 of 12
Thread: 350x STROKE 6mm
    ustin666 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    moncton
    237
    350x STROKE 6mm
    where can i get a STROKE 6mm crank and what would be the work needed to make it run.
    jrsqlc's Avatar
    jrsqlc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Northwest O HI O
    321
    try doing a search, there are tons of threads on it!!
    Visalia, CA
    720
    Go too falcon or crank works. Its a bit more expensive than powrolls cranks. But a Heck of alot better quality.
    Send in a new vershaw rod too if you go with works or falcon and they'll press it in for ya too.
    They DO NOT Shrink rods though. So you can have falcon make a spacer plate for you. (I think in my opinon keeping a stock length rod with a spacer plate is heck of alot better than powroll does to there crank rods to shrink em!)
    Shorty
    "Your 4 wheeler must be fast because you were haulin' ass....UNTIL I passed you on 3 wheels"
    RIDE RED......OR RIDE HOME
    TRIKES ARE NOT DANGEROUS......IDIOTS ARE!
    RIP
    NOS_350X is the most bad-ass person in the world
    Hyndman PA
    1,905
    Nothing wrong with shrinking the stock rod to get your stock deck heights back. The only problem I had with the Powroll cranks was when we ran big bore or 13:1 pistons.The way the bush the crank to off set the pin 3mm's left the fly weights too thin and they broke.But again this was a high HP motor,not really what they built them for.
    Over the years I have found that the big bore motors run better with out a stroker. IMO.
    Building a spacer plate and the making a longer cam chain is a pain. Then if you are not a engine builder and don't know how to re-degree a cam in and slot the cam gear you are going to have a hard time getting the power back out of it after spending a lot of money. JMO.
    Dec 2009
    moncton
    237
    i just want crank rod i can press it my self
    Pressing the rod pin in and truing the crank isn't easy, do you have experience with that??
    Mar 2007
    Texas
    5,045
    DC, KaBlewy!
    ________________
    https://www.mikesatvfix.com
    Dec 2009
    moncton
    237
    where can i buy the connecting rod.
    Hey shorty do you have any pic of there stroked 350 cranks I have seen powrolls. I just want to know why them over powroll they have been around for years and a pretty bike name in the 4 stroke world , any way I never heard off the other places I posted the prices of there cranks in my 350x cam thread
    Quote Originally Posted by ustin666 View Post
    If you can press it in yourself why can't you find a rod? Does Vesrah work if nothing else is available?
    I just read an add on EBAY that they give you a new rod/pin/bearing/washers and press it in/true it for like 135$ or so; I forget but it was reasonable and not Vesrah.
    Visalia, CA
    720
    Quote Originally Posted by big specht View Post
    Pm'd you.
    Shorty
    RIP
    We'd ALL like to see whats the difference in the pricing and quality, keep it here will ya please........
