They run strong with 90psi. A new bore should be around 120-186(manual says 186 lol)
is the plug covered in gas or oil? sounds like oil.. If it's sat around for years and has old gas, it will idle but die when you give it gas, old gas sucks. It can also smoke on old gas.
After i rebuilt the top end on mine, it runs really well. New bore and resurfaced the head and cylinder. Also new valves and 1 valve guide.
But, if it idles, it has compression to run. I say make sure your carb is set right, the needle needs to be in the middle. Fuel screw (off the top of my head) i believe is 1 1/4 turns out. A fouled plug will also cause similar issues, book says ngk b7es. Make sure your coil is grounded well, they like to rust under 'em.
When adjusting everything, I'd go ahead and run the trike over, give it a nice tune up. New oil(motorcycle oil!) manual says 10w 40. Valve clearances need to be set. .05 for intake and .07 for exhaust.
