Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: kwaski klt 200--ISSUSES- HELP!!
    missouri
    127
    my fuel pump is working great, but i may have found part of problem my CDI unit is half fried.. so im am hoping it will fix the problem atleasst most of it. most of atv or atc the cdi is not supossed to come apart, but in this case the center pulled right out and the sauders and capicters were broke and burnt,so therfore it was just getting enough fire to idle i guess? we will see after 140.00 $$ later-brand new with 1yr warrenty
    Wichita, Kansas
    1,361
    Carburetor Specifications according to my manual:
    Type PW26
    ID Mark 1811
    Main Jet #105
    Pilot Jet #42
    Pilot screw(turns out) 2
    Jet Needle NO4E
    Clip Position 3
    throttle Valve Cutaway 3.0
    Fuel Level 1.5mm
    Float Level 20mm
    Fast Idle Link-to-Cam 2-2.5mm
    Fuel Required - 91 Octane
    Fuel Pump pressure - 1-21 psi(service limit.7psi)
    Fuel Pump output(per minute) 350cc(12oz) (service limit 300cc-10oz)
    Air Cleaner Element Oil - SE Class, SAE 30 or aftermarket air filter oil
    I'm going to post up a thread about useful info outta my manual - settings, and other stuff
    missouri
    127
    91 octane? huh i have been running 89 cause thats all we got around here or 93.
