Results 1 to 14 of 14
Thread: help..cutting 200x kickstart gears
    Dec 2003
    79
    im sick of my kicker slipping. esp with 2300 into it. and the motor apart 3 times now...ive read the fourms on undercutting the kicker gears..but did any body have good results doin this? im pmed a couple dudes but noone wrote back..just looking for alil help or words of advice..and like i said whos had a sucess doin this???
    Jan 2011
    WI
    134
    pm me if you get some info on it. i need a lil help to lol
    1985 70
    1985 200x
    1985 200x hot shot
    1985 200x part trike
    1983 185s
    1993 fourtrax "whoretrax" everyones had a ride
    1967 suzuki hustler 250 2 stroke
    2004 buell blast 500
    Sep 2007
    100mi west of Chicago
    3,582
    Did you find the thread where they posted pics and how to do it? I think they have had good success with it, probably the only sure fire fix
    Rob
    Jan 2011
    WI
    134
    http://www.3wheelerworld.com/showthr...outions-inside!
    i found this just now. looks like it wouldnt be to easy but neither is push starting the 200x
    1985 70
    1985 200x
    1985 200x hot shot
    1983 185s
    Dec 2003
    79
    yea i read that thread and seems easy plus i have 2 ets of gears just didnt kno if it actually solved the problem
    Dec 2003
    79
    anyyybody???
    6,819
    Yes it works , I have done many this way but the spring still needs upgraded so it doesnt happen again . If your unsure send it to me and i'll cut them for you .
    Quote Originally Posted by trashy250 View Post
    anyyybody???
    MO
    90
    I was talking to my mechanic about doing this on my 200x. I think mine will go some day here soon.
    He said that he did do that for a customer. He said it does work for a while, but the new exposed metal is softer. He said the one he did only lasted for about a year and then it went bad again. Possible he should have changed the spring too...
    Thats what he said.. Don't know for sure though.. He did say he would do if for me though if I wanted to try it. But mine works for now. I just take my time starting it. Give the spring time to move the gear over. And never kick, kick, kick in a row. Good luck!
    MO
    90
    Do you upgrade the spring using the spring from the XR200 96 or?
    Dec 2003
    79
    yea i found the upgraded spring on ebay awhile back..read up on it i guess it has the red paint on it instead of the yellow..and its thicker i put that in n ill b ripping my motor apart again hahaha...shortline what do ya want to cut the gears ?
    Nov 2009
    Okauchee, WI
    555
    I back-cut my kicker gears a couple months ago. Relatively easy to do, read the thread in the world class help section. Make sure to go slowly and not take out too much at once. I could not find a replacement spring, so I stretched mine out a bit. Not a slip once all winter with a fresh top end.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Dec 2003
    79
    yea i reread that thread a 100 times and im sickk with a dremel so i figured id maybe try her out...just sucked cuz i went back to a stock piston instead of my high comp n threw that spring in was all siked about it...threw her together kicked 3 4 times perfect then busted my leg cuz it slipped..so i just got drunk
    Nov 2009
    Okauchee, WI
    555
    I went with a stock piston also. Guess I want to see haw the kicker holds up. If it makes it till fall I probably go with a 10.5:1 piston.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    6,819
    I use a 1" table top belt sander to cut the ratchet gears . I feel I have better control doing it that way over the hand grider .
